Porterbuilt Hood Hinge Question
I have the kit with gas assist I got for my 71. I installed the everything, got it adjusted and aligned. Than I couldn't get the hood open enough to get my hand under it to lift it up. Did I do something wrong?
How are you guys getting the hood to pop up enough so you can lift the hood open? Last edited by Jayschevy; 08-28-2013 at 12:52 PM. |
![]() Join Date: Mar 2012
Re: Porterbuilt Hood Hinge Question
On my truck I have to lift up on the front GMC emblem to open it. Mine barely pops up at all. I am still running stock hinges. Did yours work better before you changed hinges?
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
Nobody has the PB hinges?
Well I left a message with Porterbuilt yesterday but haven't gotten a call from anyone yet. Needing to drive my truck tomorrow, I decided to try and use a spare set of shaved door pushers I had left over from another project. They worked great. They pushed the hood up just enough to allow me to get my fingers between the hood and grille. This allowed me to get under the hood to lift it.
I'm not sure why I couldn't lift my hood after installing the PB hood hinges but at least it's working now[IMG] ![]() [IMG] ![]() |
I'm sure Nate will get back to you. He has always been VERY good at returning my phone calls even on weekends. I have those on my Suburban and haven't had any issues. Looks like your fix is a pretty good idea though!
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
Yea I'm sure he'll get back with me sooner or later but I had to come up with a quick fit if I wanted to go to a show tomorrow.
My hood is a huge pain to open...i have to wedge my fingers in there and pull as hard as possible...sometimes i have to get a 2x4 from underneath and push up. I still have not found and way to get the hood to pop open.
stick the 2x4 in at the wheel and have someone else hit the hood release...two man job=ghetto fab
How hard were those hinges to locate to firewall and hood and get just right and mounted?
Wasn't too hard to get it aligned. Since I don't have fender wells I could close my hood and mark the upper hood plate locations from underneath. Than I welded the upper plates to the hood. It's not the official way to do it but it worked for me.
sounds like you have an issue with the spring assembly on the latch? I have no shock assist pb hinges and it pops up when the latch is released.
#13 |
![]() Join Date: Jul 2007
Thats the way to do it. I'll do it that way next time.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
#14 |
I have a spring on the latch assembly that helps it pop up
Posted via Mobile Device |
#15 |
#16 |
![]() Join Date: May 2007
adjust your stops on the front on the grill and install new rubber hood bumpers on the fenders and it will pop right up or at least it worked for me
#17 |
I would also like to see a picture of this spring since my truck does not have one
#18 |
hi guys!! I have one question, is that mod expensive?? I really hate my hood hinges, I can't get them to work properly, they have already fixed 'em 3 or 4 times and I'm just waiting for the fifth time. Do you know a site that sends parts to Mexico?? And is it possible they don't charge me more money for delivery than the part itself?? thanks!!
