H2o Flow Problem
Having some overheating issues,
![]() Thanks!!
8/24/13 First Classic Truck '67 ![]() |
Re: H2o Flow Problem
If I was a betting man, I'd say it was cavitation in the water pump. When the water pump sometimes gets a big air bubble it will start cavitating (a lot like a boat prop spinning when it's not all the way in the water) causing low to no water circulation. More than likely when you shut off the engine, the pump slowly filled up with water and started circulating again after restart.
Posted via Mobile Device |
That makes some sense Green Mon., I drained the system, including the block, completely prior to running the water through it. Thanks
