Laying frame or cross member and heater box question.
Those of you that are laying frame or cross member did you keep the heater box? I plan to lay frame on a 29" tire and want to keep my heater. How can this be done? My tire is close to the heater box now and I'm not all the way down yet?
Re: Laying frame or cross member and heater box question.
You can move the blower motor up. I have seen people here do it. I dont know about the ac box though.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
If you are planning on new control arms, you can go with the Porterbuilt and get the 1" forward. This will give you a little more clearance for the heater box and also center up the wheel in the wheel well when aired out.
If you want to lay frame and get more firewall/heaterbox clearance you can,
Install a Dropmember + Forward arms Z the frame and move the front wheels forward at the same time. The Z is mostly all labor and not a lot of $ BUT you need fab skills (or a friend or shop) The Drombember and arms you need a LOT of $$$ and not so much skills
A Dropmember, new arms and doing a Z is out. Is there any way I can narrow the heater box?
Happy to be here
![]() Join Date: Mar 2000
You can section the heater box, but that means the squirrel cage on the fan motor will have to be cut down too.
What about going to a vintage air or summit heater? The summit one should fit under the dash and Jang prohibitively expensive.
