Old 08-28-2013, 05:50 PM   #1
jessewebb
jessewebb's Avatar
how much sound deadener
Anyone now how many square feet of sound deadener I would need to do the firewall, floor pan, under the seat and up the back of the cab, also under the door panels. Any suggestions on how thick. 50 mil, 70, 80, 100. I know the thicker the better, but it also costs more. Is 50mil thick enough with padding and carpet? Anyone care to recommend a good product? dynamat, fatmat, gtmat? Thanks for any help in advance
Pete
The worst I ever had was wonderful
69 SWB work in progress
97 Ranger 6in. lift on 35's
04 325i lady's ride
jessewebb is offline   Reply With Quote
Old 08-28-2013, 06:37 PM   #2
Lee H
Lee H's Avatar
Re: how much sound deadener
I used dynamat, you can see a few pictures of the installed product in my build thread. I used a tape measure to determine how much to buy. There are some good deals on fleabay to buy in bulk.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-28-2013, 06:55 PM   #3
jessewebb
jessewebb's Avatar
That's some good advice, I'll do some measuring first. Thanks
do you know what mil you used 50, 80 ?
Pete
04 325i lady's ride
Old 08-28-2013, 06:57 PM   #4
Lee H
Lee H's Avatar
Not sure on the thickness. Sure makes a HUGE difference in sound and temp inside the cab.
Old 08-28-2013, 07:17 PM   #5
Rich916
Rich916's Avatar
I used Fat Mat, I bought a 50 Sq Ft bulk pack and it coverd eveything.
Rolls out nice and easy installation.
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Rich916 is offline   Reply With Quote
Old 08-28-2013, 07:35 PM   #6
FLDBRED
If you want to save yourself a ton of money, take a look at Frost King air duct liner. It is available at Lowes and Home Depot.
FLDBRED is offline   Reply With Quote
Old 08-28-2013, 08:20 PM   #7
Tinkermc
I bought on fleabay 2 rolls of Dynamat nd had about 1/4 roll left over. Did a fine job.
Tinkermc is offline   Reply With Quote
Old 08-28-2013, 08:40 PM   #8
jessewebb
jessewebb's Avatar
Rich916 you've sold me. That is an awesome job. Looks perfect. Thanks
Pete
04 325i lady's ride
Old 08-29-2013, 04:43 PM   #9
Rich916
Rich916's Avatar
Glad to help, The roll comes with instructions, knife and roller.
I would also recommend getting some aluminum tape (home Depot, Lowes) for seams.
Old 08-29-2013, 09:03 PM   #10
MidLifer
MidLifer's Avatar
Here I go the broken record again - the mat products are not sound deadeners, they are vibration dampers. They won't stop road or engine noise on their own. They will, however, keep your truck's cab from resonating.
See www.sounddeadenershowdown.com. Firstly, if you believe what that guy says, you only need to cover less than half your sheet metal with a mat like fatmat to achieve the effect. Anything above that is overkill.
BUT, to achieve sound deadening, you need to add a layer of isolation foam and then a layer of mass-loaded vinyl. There are "sandwich" products out there that have all 3.
I know there are as many opinions on this subject as there are people and I'm certainly not looking to start a thread-locking argument. What I will say is I followed the recipe on that website and am very pleased with the results.
Mass-loaded vinyl is a bit tricky to find - I oot my MLV locally, a guy had some surplus from a building job and I found it on CL. MLV is very heavy and shipping will kill you if you order it. Better building yards carry it.
MidLifer is offline   Reply With Quote
Old 08-29-2013, 09:23 PM   #11
jessewebb
jessewebb's Avatar
That's some interesting facts, Thank you
Pete
04 325i lady's ride
Old 08-29-2013, 10:03 PM   #12
jmorri34
jmorri34's Avatar
Man I checked out that link, thats some interesting info!! When I do this, I was thinking about doing the whole cab and inner doors, but from the info here, like you said you could probly do like 50% and get the same reduction. Good link!!
jmorri34 is offline   Reply With Quote
Old 08-30-2013, 06:20 AM   #13
nobolt
nobolt's Avatar
there was an ad I remember...
they took a 4" square of matting and stuck it on a bass drum. it killed the sound.
Dave
"... government even in its best state is but a necessary evil. Thomas Paine
"It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men)
nobolt is offline   Reply With Quote
Old 08-30-2013, 06:33 AM   #14
Bigdav160
Bigdav160's Avatar
Yes, because resonance is felt and heard. :wink:
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-30-2013, 09:10 AM   #15
MidLifer
MidLifer's Avatar
Here are pics of my sound deadening project:
https://plus.google.com/photos/11025...CIHs7-nc5vabJQ
I know a lot of guys do their whole interiors with mat and are happy with the results. I'm sure there is some reduction of transmitted road and engine noise with mat, maybe as much as with MLV and foam. I did hours of reading on this and other forums before I chose my direction, probably too much. It cost more than if I had just used mat on everything as well. Maybe I'll try all mat on truck #2 (the 1950 1/2 ton step I just bought) and compare the difference.
Old 08-30-2013, 08:08 PM   #16
ItsRandy
ItsRandy's Avatar
I too read a bunch on the subject of sound deadening. As I understand it; strips of mat ( I used a product called "Road Kill") with spaces in between is all you need, covering like 50% of the floor/firewall. I just couldn't believe the science behind it (true as it is) and covered everything that was going to be covered by carpet with mat and I'm not sorry I did.
ItsRandy is offline   Reply With Quote
Old 08-30-2013, 09:56 PM   #17
C_Ruiz
Did anyone run into any issues with the carpet fitment after the dynamat/sound deadening installation?
C_Ruiz is offline   Reply With Quote
