What is the right dash set up???
The shift indicator gauge on my '73 automatic was broken. I took the column apart to find out it was a broken plastic part on the gauge cluster. So I went to the junk yard and grabbed another.
Got it home and found out it was for a different set up and did not have the correct holes for lights and plugs. Went back again and looked real good and found one that looked like it would work. Got it home and realized that the oil pressure is electric and not mechanical. I decided to keep it and just drill a hole. This meant swapping the flat electronic card in the back. After doing that I hooked everything up and now the parking brake light comes on with the headlights. I'm getting frustrated because as some of you know this is not the easiest part to swap. Any advice?
1973 Chevy K20 |
Re: What is the right dash set up???
Why don't you cut the broken one off and and cit the goof one off and expoxy it to yours if you don't find a correct .cluster
Also remeber all clusters are pinned different so its not always plug and play Posted via Mobile Device
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
Would epoxy hold it? It's a small tab
1973 Chevy K20 |
78K & 79C Jimmys
I've read some have success with reglueing in the tab
i'd compare the boards if your swapping I know the wires do change looking at three styles I have heck even the postion of them changes
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
| Bookmarks |
