Recommended headers?
Looking for suggestions on a set of headers for my truck (70 w/350SB and AT) that will give me the most space from the starter, to minimize the heat soak. I currently have a set of Shorties on it hat fit nice but the collector is right next to the Starter motor, and I've burnt two starters to date. I considered going bak to factory Rams Horn manifolds, both for the look and feasibility. I'd kinda like to stay away from the long tube headers as the collectors hang a little too low for my liking. Yhanks up front to any suggestions.
![]() Join Date: Mar 2012
Re: Recommended headers?
I have flow tech shorty headers on mine. They are for a 67 Camaro/Chevelle. They tuck nicely and I have had no problems with the starter getting too hot.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
How are those FlowTech shorties for plug access?
![]() Join Date: Apr 2008
Have you tried a smaller starter? I think there was a Corvette starter that is smaller so it would give you more clearance.
I have used a starter for a 1994 Caprice with a 4.3 V8 in the past on an S-10 drag truck with a small block. It worked great and was considerably smaller.
GobbleStalker Calls
![]() Join Date: Aug 2010
I just bought the Sanderson shorties and they seem to fit really nice.
Kevin.
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino. Stay Tuned! 1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD! 09 GMC Sierra SLT All Terrain pkg. 2014 Jeep Wrangler Sahara unlimited. ( The wifes ride ) |
#7 | |
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
You could try putting some reflective thermal barrier fabric between the collector and starter. I had a similar issue on my Harley with the rear cylinder exhaust too close to the battery box. Put some DEI heat reflective fabric around the battery and no problems since.
Picture of starter with wrap attached.
