08-29-2013, 10:11 AM | #1 |
Old member
Speakers and Amp
I want to know if this is right.
I have 2 10" subs mounted behind the seat. 2 -3ways mounted under the seat 2- tweeters mounted on the cab walls 2 mid ranges in the stock dash area. I have a cheap 100w amp running the 4 smaller speakers, tweeters, mids. this is off the front RCA jacks. I have another biger amp running the 3 ways and subs hooked through the rear rca jacks with y connectors for a four channel amp. What I want to know is can I hook another amp up to the y connector and bridge the 2 amps to run only 2 speakers each. I have another 4 channel amp which is 800w that I can use to power the 2-3ways with. What do u think?
08-29-2013, 05:13 PM | #2 | |
meowMEOWmeowMEOW
Re: Speakers and Amp
Take the "other bigger amp" (4 channel), and hook the mid ranges to the front stage, with the tweeters running off a powered crossover instead of off the amp. Then hook the 3 ways (Effectively the rear stage), and hook them to the rear set of outputs on that same amp. That puts all your speakers on 1 amp. Then assuming your head unit has 3 outputs, take the 800w amp, bridge it down and hook ONLY the subs to it . If you don't have 3 outputs, you can still do the same, but it would make the speakers all run off the front signal, since the rear signal has to get changed to sub output if you don't have 3.
08-29-2013, 08:09 PM | #3 |
Old member
Thanks for the info. Now if I only knew what u meant by a crossover!!!!!
I have the small amp hooked to the front RCA jacks that run the four small speakers and the rear rca's run the 3 way and subs. I could swap the amps out and make the 800w drive the subs and let the 400w drive the 23ways could I by unplugging 2 of the rca plugs and plugging them into the other amp and then tie all the power leads together behind the seat. Is this right thinking are am I way off. One thing I'm trying to avoid is pulling the carpet up and rewiring the whole system. All the small stuff is wired under the dash and the bigger stuff is ehind the seat.
08-29-2013, 09:13 PM | #4 |
78K & 79C Jimmys
my crossover is below my head unit
one line in ,splits to 3, low,med ,high-all ajustable seperately allows for ez ajustment being up front others types may just mounted some where
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
08-30-2013, 12:29 AM | #5 | |
meowMEOWmeowMEOW
The way I described would run only 2 amps, eliminating the pretty 100w amp...it doesn't need to really be in the system if wired correctly, and it sounds kinda wimpy. There isn't any reason for the 3 ways and the sub to be on the same amp, since you would then be running a 4 channel amp, over to 2 speakers drawing X watts, and 2 subs drawing XX watts. If a 4 channel amp is lets say 400W (peak), that means its like 50w rms per channel. That 50w is fine for the speakers, but pathetic to drive a 10" sub. Your doing both speakers a disservice running them that way.
08-31-2013, 01:02 PM | #6 |
Old member
OK,
that what I was thinking. I guess I need to pull the whole system out and redo it. Man I love my truck!
