Old 08-29-2013, 10:22 AM   #1
UATahoe
Possible to lower my 87 and keep the 30.5" tires??
Just bought new tires for my 87 and was curious if a 2.5/4 drop would still allow the 30.5" tires to fit. If not, i will just keep it stock height. Any opinions of feedback would be great. Thanks!
UATahoe is offline   Reply With Quote
Old 08-29-2013, 11:58 AM   #2
Ziegelsteinfaust
Re: Possible to lower my 87 and keep the 30.5" tires??
I have a C20 with 265/70/16's a 31 inch tire, and I can do a 2/3 easily. Maybe even a 3/4.
It depends a lot on if you rim/tire will tuck to the inside of your truck. Then if your new ride height will allow enough suspension travel for what you do.
Ziegelsteinfaust is offline   Reply With Quote
Old 08-29-2013, 12:04 PM   #3
UATahoe
Good points. Rims are stock rally wheels. Drop would be spindles and shackles. No off roading either. Just a daily driver.
Old 08-29-2013, 06:23 PM   #4
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I had 3 inch drop spindle's on my Dually with 31 inch tire's for a long time, no issue's .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 08-29-2013, 06:55 PM   #5
UATahoe
Would be great if I could still drop the truck with the larger tires. Would be a good look to me.
Old 08-29-2013, 08:26 PM   #6
tinydb84
tinydb84's Avatar
I have 29.5 inch tires on a C20 and I dropped the back 6 inches with more room to go
David
Instagram: myfabguy
Old 08-29-2013, 08:28 PM   #7
UATahoe
Should clarify to that my truck is an R10.
Old 09-06-2013, 03:00 PM   #8
UATahoe
Aside from being possible, anybody think it will look bad being lowered with the larger tires? Thanks for all of the opinions and feedback!
Old 09-06-2013, 03:37 PM   #9
Ziegelsteinfaust
No, unless the tires poke out past the fenders or you run serious off road tread.
Old 09-06-2013, 03:39 PM   #10
UATahoe
Shouldnt stick out and the tires are Cooper Discoverer AT3 tires. Not an aggressive tread pattern at all.
