K30 Dually E-brake
Anybody have a pic or diagram of how the e-brake cables need to be routed?
Pretty sure duallys have a different setup then single rear wheel trucks. Checked my K20 and both cables meet and run up to the pedal. Thanks
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
Re: K30 Dually E-brake
Maybe a C30 might be close?
I'll snap you a pic or do my best to describe my setup when i get home from work for you, I have an 83. Are you interested in all the way from the pedal to the drums or need anything else specific?
Next!
![]() Join Date: Jan 2003
I have duallys and srw 1 tons, the difference seems to be whether you have a 14FF or a Dana 70 and 84 and up is different than 83 and back, which are you looking for?
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
I have the cables coming out of the drums and the cable that comes out of the cab, just to see what goes between those cables, pretty sure it's one cable that runs in a U to both of the rear cables then the cable from the cab hooks on somehow.
Next!
Does this help?
GM72K10 That looks like a single rear wheel setup, just like my K20
Next!
You're right, my 83 dually is like that but not my 86
Next!
and it has a connector on both sides with a cable that links around to the front
Great pics, thanks Must be different 84-up, my k30 is a 82.
At least with your pics I will have some to go by
| Bookmarks |
