08-29-2013, 04:23 PM | #1 |
Seperating of hub and rotor
To separate the hub from front rotor on 71 dish brakes, Do I just need to press out the lug bolts to separate the two or do I need to press the center hub off as well also. Original combo since Blazer was new. Thanks for any input........... Mike
08-29-2013, 05:40 PM | #2 |
Re: Seperating of hub and rotor
You have knock out the studs first. Easier if you have a brass hammer. Put the brass hammer against the stud then with a larger ball peen hit the other end of the brass. 2 hits the stud should be out. The hub should fall away from the rotor at that point unless major rust has ensued
08-29-2013, 07:57 PM | #3 |
I use a large press to put the studs back in
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
08-29-2013, 10:41 PM | #4 |
Thanks guys, I was just checking to see if I needed my press to remove the studs or just use the hammer and drift method...Will use press to reinstall studs.. Again thanks for your input....Mike
