Brake lines with disc swap.
Hey guys I'm about to order the new brake lines for my truck. I have a '68 short bed and I'm swapping to power discs in the front. I was going to grab Inline Tube's part # CTB6803 (1968-69 Power Drum Short Line Set 9pc 1/2 ton Coil Rear), and get the CPP drop spindle / 6 lug disc kit. I already have the booster. What I'm wondering is how the master cylinder and prop valve lines up with the stock drum brake lines. Will the stock lines line right up with the prop valve? I know the drums have the prop valve right next to the master also, but it's more of a distribution block. Any of you guys that have done this swap, let me know what to expect, so I know which brake lines to get. I have to get the 68-69 brake lines for this either way because of the narrower axle.
Thanks! ![]() |
Re: Brake lines with disc swap.
Al,
If I remember correctly you can place the prop valve anywhere you want. If they dont line up, cut, bend and the reflare them to wherever you want. I may be wrong but I believe Ive seen them put on frame rails before.
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
Yea i figured I could make it work like that, I have all the tools, just wondering about how they do the kits and if there's a better choice for the stock lines, since I have nothing. I'd rather get the right thing first than make something work that's not quite right. I know the only difference really will be at the master cylinder, so I could mod that if need be. Thanks!
#4 | |
#5 | |
Actually when it comes to stuff like the master cylinder and stuff like that I'd rather get something new... kinda like getting used tires, I'd rather start fresh than use something of unknown condition... who knows how long the seals will last, etc. I'll grab the prop valve from you though ![]() ![]() From the diagrams on the web I have found and on the LMC catalog, they look like they are routed the same for power drums or discs. That kinda makes sense. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've always used the entire stock GM line set from a 73-87 truck. From the master cylinder to the prop valve all the way to the calipers and to the junction on the frame rail for the rear brake line. It all bolts straight in without mods. No bending, flaring, or cutting.
Posted via Mobile Device |
#7 | |
Not at all.
There is a junction on the inside of the frame rail in the rear brake line. You change it from there forward and leave the back section alone. Posted via Mobile Device |
#9 | |
#10 | |
Sold that last night.. $20, you missed out my friend...
Here is a 63 model truck I built. The entire brake system from master cylinder out through the prop valve, lines, front hoses, and calipers are stock 1980 truck. I didn't have to build a single line. It all bolts in.
![]() ![]() The hoses bolt right through the frame rails to the stock 1980 model lines. I used new braided hoses, but they're stock 73-87 truck fitment to match the rest of the new system. ![]() There is a single line that runs across the frame and back down the rail to the rear brakes. There is a junction about halfway down the frame rail in that line. I broke it there and bolted the 1980 model line to the stock 63 model rear half. From there back, its all stock 1963 lines and rear brakes. Posted via Mobile Device |
It's all about timing!!! LOL!!!
No biggie, looks like I can pick up a master with a prop from a few places. Just money either way! ![]() |
#13 |
Ditto what Tx Firefighter is telling you. It is such an easy bolt-on, it is hard to understand why more people don't do it. It hides the combination valve down on the crossmember, under the radiator. I used all the front lines from the '76 I took the discs from.
In his picture that shows the brake line going through the frame, those holes were already there on my '67. I had to drill them larger. The in-line coupling on the rear line is just as he described it. I recall that it is under the pass side floor board.
'67 GMC 2500, 292, 4spd, AC |
#14 | |
BaBaBooey BaBaBooey ![]() GO SPURS GO!!! |
