Need fuse block help!!
I was hooking up a stereo in my 79 today. I took the constant power wire off of the terminal I am pointing at in the pic. When I was running the wire to the deck it shorted out. I wasn't thinking. Now there is no power there, and I can't find any blown fuses. Any ideas? Dome light don't work now.
Posted via Mobile Device |
Re: Need fuse block help!!
Is that your only fuse box? Anything under the hood?
1973 Chevy K20 |
No fuse block under the hood.
How bad was the short?
Check the fusible link at the starter
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer. |
The wire I was running just brushed a bracket , everything else in the fuse block still works, its just dead where the dome light wire plugs into the fuse block. Any other fusible links in the system other than at the starter?
| Bookmarks |
