Exhaust question
Are the exhaust systems for all 73-87 sbc's the same? I've got an 81 and I'm looking to add a dual system to eliminate the cat and pick up some power. I'm looking at this set
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=159 Muffler shops in my state won't remove cats. They can only add new ones in. That being said it's cheaper to buy this set and have it shipped (about $330) than have a local shop build a system and pay for 2 new mufflers and 2 high flow cats. The only thing is LMC lists them up to 78 since after that they went to cat. converters and legally LMC can't sell them as a removal of cats. Manifolds on the SBC should be the same regardless of year correct? |
78K & 79C Jimmys
Re: Exhaust question
most won't remove them,but if they can fall off on the way.....they will fix the leak lol
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
It doesn't say it won't fit, just that it is only legal on year without a cat.
Summit offers this kit, It might be a cheaper option, even having to buy mufflers. It is designed for trucks that came factory cats. http://www.summitracing.com/parts/wl...olet/model/c10 You can get the correct style mufflers for about 34.00 each. http://www.summitracing.com/parts/wlk-17655/overview/ |
#4 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
![]() ![]() ![]() Posted via Mobile Device |
I've actually had the cat fall out before. On my sentra the muffler shop wouldn't even weld on a muffler downstream if the manifold cat AND downstream cat (not monitored by the ecm) wasn't installed. Now my exhaust manifolds are different than yours in the pic. The driver one dumps between 5/7 and the passenger side dumps between 4/6. They come out of the head and curve up not down. Wires are under the manifolds. It also has a vacuum actuator on the passenger side. I'm also not sure how its assembled. If its in peices like the dynomax then I can cut my old pipes and remove the flanges and use them on the new system as long as lengths are the same since yours are rear dump. That would make all the angles and length at the manifolds different.
With the summit kit will it allow room to clamp in the mufflers? No need to weld or cut Last edited by Recian; 08-30-2013 at 12:42 PM. |
#6 | |
On my '86 blue Chevy I sold back in February/March I got the dual pipes from a salvage yard, bought new Summit chambered mufflers (Flowmaster type), and spent something like 65 bucks TOTAL out of pocket including the pipes, new mufflers, a $20 Summit Bucks coupon and free shipping code. Hopefully I can find a set of 2.5" or 3" duals for the 454 now because the dual cherry bombs and dumps sound like crap to me.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
I wouldn't mind some shorty headers but the only ones I can find are turbo mount center dumps. They don't fit to these pre bent systems well
#9 | |
After talking to a few exhaust shops, I think I going to order both the links for my 77 that I posted. The local shops are nuts! They want 450-500 plus tax for the same exhaust. |
Exactly why I figured 300 or so would be good. I ended up putting my exact truck info in and that kit still comes up. That kit lists for all 73-87s so I assume it'll fit early and late models with slight adjustments depending on model. just re-use your existing flanges, just cut the original exhaust pipes, remove flanges and install the flanges to the new ones before assembly.
I'm going to the junkyard tomorrow so MAYBE I'll come across something there that I can remove and put on my truck even if I have to take the manifolds with it. (cheaper when you don't disassemble) |
the dynomax kit is a good deal, cant do it much cheaper yourself. unless you can bend it
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
The dynamax looks to be a stock exit system not a rear exit
#13 |
Wow, I hate it for you guys they are so stringent on the emissions on your trucks. Even when we had inspections as long as the cats were already cut off they would do any exhaust you wanted. The same shops installing the exhaust for you were the same ones doing the inspections though. Since they quit doing inspections it is pretty well a free for all here now. Not bragging, I just can't imagine having to deal with this.
If you live in Oklahoma click this link |
#14 |
Sad thing is in 3 years my truck will be inspection free. No more inspections but legally the shop can't take my cats out or even work on an exhaust that has no cats. It's like a federal law but I'm sure states without big emissions regulations don't enforce it.
#15 |
The more I look at the pic on LMC's site I think it'll still fit my 81. The pass. side has a 45 degree header rear dump angle and the driver side is a straight down dump that leads into a 90 degree bend a bit more forward of the passenger side's dump. My only worry is the heat riser and how it'll fit around that. Now that I think about it that could be causing me some power issues too since my engine seems to bog at random times and usually under heavy throttle
#16 | |
I just ordered the summit/dynomax kit with the welded thrush mufflers, 223.91 to the door. Summit has free shipping for anything over 100 bucks. |
#17 |
I've got the thrush mufflers and YEA! FUN!!! U could weld one up yourself. Welding is a lot easier then it seams and u can get what u want for cheaper.
Faith and Patience with my truck, that is what i pray for every day! See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013 |
| Bookmarks |
