08-30-2013, 12:45 PM | #1 |
Help lowering front 5 inches
I am interested in lowering the front of my 65 5 inches on the cheap.ideas please without spindles.
08-30-2013, 01:20 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Help lowering front 5 inches
Nothing cheap, if your going to do it, do it right. 2.5 drop spindles and 3" drop springs. Spindles and bags, either way.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-30-2013, 01:55 PM | #3 |
Junior Member
He's right. I'm as cheap as it gets HAHA but I went with 2.5 drop spindles and 2" drop coils...So I guess technically not 5, but pretty damn close. I'm going with air ride later
08-30-2013, 03:14 PM | #4 |
Whats the lowest you can go with just springs without having it ride like hell?
1966 C10 250 with 3 on the tree Build Thread Bunch of other cars no one cares about |
08-30-2013, 03:31 PM | #5 | |
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
08-30-2013, 04:01 PM | #6 |
I know they sell 3" drop coils. I have only rode in 1 vehicle with cut coils and it wasnt very good ride. Either buy the springs, buy the spindles or just forget about it.
08-30-2013, 04:34 PM | #7 |
Yeah in my case just curious on a aftermarket spring only drop, not cut. I should have been clearer.
08-30-2013, 08:49 PM | #8 |
Super cheap heat the springs with a torch. I wouldn't recommend it.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
08-31-2013, 03:58 AM | #9 | |
can do it the right way. You will be much safer on the road and safer for others that have to share the road with you please..Vernski |
09-01-2013, 12:07 AM | #10 |
My fronts are cut and it hits hard on almost any bump. I'll be putting springs spindles and discs up front next year. I might get some shocks for now and then use them next year with the new set up. Everyone is right, save up and do it right and you won't be disappointed. Do it cheap (wrong) and you will be disappointed and dangerous.
66 shorty |
09-01-2013, 10:32 AM | #11 |
I have cut the last two C10's and it rides great. On the first truck, I too thought that I was bottoming out. via. lower control arm, but I wasn't. My shocks were. The compressed length was too short. I replaced the shocks with a shorter compressed length and voila the ride was great, no bottoming out.
Check it, http://67-72chevytrucks.com/vboard/s...d.php?t=573266
09-01-2013, 11:14 AM | #12 |
Just remember that if you go down 5" in the front, the lower control arm height to the ground become the bigger issue. I've had them this way, but you have to change your driving habits and be very mindful of what's ahead in the road and react accordingly. When you bash the lower control arms off of the ground at 55 mph, that gets your attention quickly. And it beats the LCAs to death.
Low=slow.......
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
09-03-2013, 10:23 AM | #13 |
Thanks for the input guys thinking i may just go 4 inches instead of 5.
09-03-2013, 10:26 AM | #14 |
67-72 parts collector,…
3" drop is the max with just springs.
09-03-2013, 10:27 PM | #15 |
I have run cut springs for over 30 years..........never once have a issue.
but use 3/4 ton springs
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
09-04-2013, 12:31 AM | #16 |
ive cut a frw trucks and never had a problem smooth. cut two turns , removed the rubber snubber and bracket. the moved the upper shock mount up higher.
