Old 08-30-2013, 01:13 PM   #1
SoCalSlaughter
SoCalSlaughter's Avatar
Rough idle - Hard starts - Cold starts
Always something with this truck.. haha Well the truck is a 1990 Chevy V2500 4X4 Suburban, 350 tbi. The truck recently has been having a problem during cold starts. Go to crank and motor will turn and it will try to run, but stumble and die. It will only run if I hold the gas slightly. After holding the gas for awhile til it starts to warm up, I can then let off the gas and it will stay running on its own. Also, once it is warmed up, and I go to the store, or get gas, and go to restart the truck, it will turn over and run just fine, but starts up with a low idle, about 500 rpm. Once I throttle it the idle will come back up to around 700 rpm. Put the truck in park after its warmed up and the idle will be around 1100 rpm. I also noticed a drop in gas mileage. ALSO! lol I notice when the truck is started cold, it has a slight miss. I can hear a pop or puff from the exhaust every few seconds until it warms up then seems to run better. Ive already swapped out a IAC unit, reset computer, sprayed carb cleaner around tbi and intake. Thanks!!
SoCalSlaughter is offline   Reply With Quote
Old 08-30-2013, 06:14 PM   #2
Lee H
Lee H's Avatar
Re: Rough idle - Hard starts - Cold starts
Is the check engine light on or been on recently? When was the last time it had a real tune up?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-30-2013, 06:20 PM   #3
SoCalSlaughter
No check engine light, last time it came on for for a code 42. That was about 3 months ago. Hasnt come on since. And the dizzy cap, plugs, wires, oil, pcv, and coolant was changed about.. 2 months ago? The truck had been running fine since all that was changed.
Old 08-30-2013, 07:01 PM   #4
Rollo McFlurry
A 1990? I thought they all ran like that.
Rollo McFlurry is offline   Reply With Quote
Old 08-30-2013, 07:33 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Lot's of possibilities on these: fuel injector, TPS, fuel pump (check pressure), MAF sensor, ecm, on and on. Best thing is to take it in to have everything checked out so it won't cost you an arm and a leg replacing all the sensors.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-30-2013, 08:22 PM   #6
Special-Ed
Special-Ed's Avatar
Iac valve. It's a stepper motor with pintle and seat. Take it off and clean the surface
Also with motor off make sure the trottlebody and butterfly are clean.
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 08-30-2013, 09:23 PM   #7
Marv D
Registered Truck Offender
Marv D's Avatar
DITTO, The IAC is a problem with the early TBI. Carbon builds up on it and it doesn't want to come to 'rest'. If you start having high idle issues, the IAC is always suspect.
Also my old tried and true standby. Change the fuel filter!! If ANYTHING even starts to be a hit of a problem on the TBI motors I change the fuel filter (even if it's only been a few months since changing)
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
cold start, idle problem, miss fire
