Old 08-30-2013, 06:39 PM   #1
steppside69
steppside69's Avatar
Question Shock question
I was wondering what the best shock to use on my 69 swb step side.
I am using air bags with a 2 1/2" drop spindles and in need of enough travel
When aired up and down? Thanks steppside69
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 08-30-2013, 10:06 PM   #2
sduckworth13
sduckworth13's Avatar
Re: Shock question
Have you thought about getting shock relocators? With the shock relocators I believe you can use the factory shocks and not compromise ride quality for a shock that doesn't have enough travel in it to properly compress.
Scott
sduckworth13 is offline   Reply With Quote
Old 08-30-2013, 11:24 PM   #3
SCOTI
SCOTI's Avatar
Re: Shock question
x2. I always build my stuff to utilize OEM shock length & avoid getting cornered into using some mfr's 'drop shock'. OEM spec'd shocks were researched.....
I would use a drop shock if I KNEW they researched the pressure, travel, & stroke required. From what I've found, most use a shock that only meets the dimensions/mounts & put their p/n-stamp (sticker) on it.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-31-2013, 02:22 PM   #4
steppside69
Re: Shock question
Thanks for the replies, has anyone made there own shock relocators? I wouldn't think it would take to much to make. Or are there possible problems if I move the shock higher than the existing hole? Thanks again
Old 08-31-2013, 07:38 PM   #5
SCOTI
SCOTI's Avatar
Re: Shock question
I make my own if its cost effective vs buying something pre-made. I liked Hotchkis's front shock relocation kit but about pooped my pants when I read the price tag ($435 @ Summit). I already had Bilstein shocks so I made my own front brackets (2 brackets < $30). I even make my own if it fits my specific design requirements better vs what might be supplied w/the 'kit' I'm using (I have a Dropmember on my 64 but I didn't utilize the shock brackets w/the kit).
On my CC dually, I will likely purchase pre-fabbed rear brackets/mounts that weld to the rear end if I can find them in the correct dimensions. If they aren't made in the dimensions I need, I'll build them too....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-02-2013, 12:07 AM   #6
steppside69
Re: Shock question
Ok been doing research, whats the best/cheapest front shock relocator? In your oppinion?
Old 09-03-2013, 10:00 PM   #7
kaycee
kaycee's Avatar
Re: Shock question
I been researching allso made my own for the rear and made a big diff. in ride now I need to do the front.
http://67-72chevytrucks.com/vboard/s...d.php?t=418095
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 09-06-2013, 05:09 AM   #8
wraprail
wraprail's Avatar
Re: Shock question
I made my own mounts from the factory mounts I cut off my stock rear axle. Shocks are Monroe Matic for the rear of a 1980 Jeep CJ-7. I have since upgraded to Monroe Gas-Magnum. I use the same part # front and rear.
wraprail is offline   Reply With Quote
Old 09-09-2013, 07:12 PM   #9
steppside69
Re: Shock question
Thanks for the info
Old 09-10-2013, 02:22 AM   #10
DREAMER1
DREAMER1's Avatar
Re: Shock question
Ekstensive in Houston. I believe are $25 for the front ones
DREAMER1 is offline   Reply With Quote
