08-30-2013, 07:51 PM | #1 |
need some help
picked a suburban up and its a little rough.... trying to put the original master cylinder on. i cant seem to take this one off..heres a picture. i didnt try prying it.... really anxious to get this thing rollin...
08-30-2013, 08:28 PM | #2 | |
Re: need some help
HTH; and I know little about the early suburbans--just assuming they use the same mc's as the pickups from the same year. Sam |
08-30-2013, 08:30 PM | #3 |
Re: need some help
Did you unbolt the rod from the brake pedal ? to pull it out together, it would be much easier to get it apart in a vise.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
08-30-2013, 10:17 PM | #4 |
Re: need some help
ill have to do that tomorrow.. it should come free correct? and i should be able to put the rod back in and use the original with no issues? thanks fellas
08-31-2013, 12:44 AM | #5 |
60-66 Nut
Re: need some help
I agree on unbolting the pushrod from the pedal.
That is a later model master cylinder some of which have the pushrod secured into the back of the piston. I doubt that you will be able to use that pushrod on an original master cylinder.
08-31-2013, 07:20 AM | #6 |
Re: need some help
so basically I should try to make this work? maybe run new break lines from this master? I dont think ill be able to find the original rod. thanks for your help guys..
Posted via Mobile Device |
09-01-2013, 12:18 AM | #7 |
60-66 Nut
Re: need some help
Did someone install that master cylinder and not split the brake lines? Does your truck have front disc brakes? It's hard to tell what master cylinder that is.
