Old 08-31-2013, 07:19 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Door Won't Open, Help
Today I was at the garage where I keep my 72 and tried to open the passenger door and it wouldn't open. I thought I may have hit the button and locked it so I went inside and the button wont move up or down and the inside door handle wont work either so I can't get my door open. Has this happened to anyone else or does any one know why it would do that out of the blue. I was at the truck 3 days ago and the door worked as it should.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-31-2013, 10:22 PM   #2
FL71C10
Re: Door Won't Open, Help
All I can suggest is take the door panel off and see if you can figure out what's wrong. sound like a problem with the latch as both the inside handle and the outside handle are not working.
It will be a PITA to get the door panel off, you might need to pull the seat out.
fun..fun...fun.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 08-31-2013, 10:30 PM   #3
big mike71
big mike71's Avatar
Mine did the same thing. I had to take it apart and lube it.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 08-31-2013, 10:59 PM   #4
Already Gone
I am lucky in one way because I havent bolted my seat down yet so it will be easy to take out of the truck to get at the dor panel. You almost couldn't get the
seat bolts undone with the door closed.
Old 09-01-2013, 11:37 AM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: Door Won't Open, Help
Either the door handle button has broke the tabs off on the inside of the door are the rod that attaches the door handle on the inside has fallen off are something broke on the door latch.
The outside door handle pushes the latch itself so I would think the latch has failed in some way.
For both not to operate the latch that's my guess.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-01-2013, 12:24 PM   #6
cdowns
cdowns's Avatar
i'd putl the window down and try lookin inside with a flashlight and see if you can use a coathanger to fish the slipped broken non workin thingamajig thingy to help open the door
Old 09-01-2013, 01:13 PM   #7
Already Gone
Thanks, that sounds like a good idea.
