EFI gas tank
I am building a underbed tank for the 56.
At the moment I am running normal carb set up but in the future will go to something like FAST EZ-EFI with in tank pump. Just trying to prepare the tank so I can make the conversion to in tank EFI pump easier. Does anyone have any diagrams or photos for in tank pump fittings etc?
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
Re: EFI gas tank
I think I just looked at a setup like you are thinking about in the latest issue of Custom and Classic Truck. The September 2013 issue. They used a pump from Aeromotive http://aeromotiveinc.com/ That went in a separate opening besides the normal fuel pickup/sending unit.
It's a new issue so it may not reach you for a while but I have an extra copy (forgot I got a subscription) if you want a closer look I can put it in a plane brown wrapper and send it to you. The way they do it you could retrofit an existing tank pretty easily. The magazine used this unit http://aeromotiveinc.com/products-pa...h-fuel-system/ for the article.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 08-31-2013 at 11:39 PM. |
Re: EFI gas tank
Thanks Mr48.
I think this is the article you are talking about. http://www.customclassictrucks.com/t...nk_relocation/ I do like the Aeromotive pump option but EFI will not be on the cards for me this year. Currently running a 4 barrel carb but I am relocating the tank to under bed location. The tank is partially built. I want to continue to use the carb for a while and then when I am ready for EFI I want to have an easy retro fit of the in tank pump. So I am just trying to get some ideas on the best way to set up initially for carb / mechanical fuel pump and have an easy transition to EFI / in tank pump (hopefully later next year)
Re: EFI gas tank
Another alternative...
http://www.tanksinc.com/index.cfm/pa..._id=6/art6.htm Posted via Mobile Device Posted via Mobile Device
Thanks, srengr -------------------------------------------------- 1959 3100-- Mild Resto-mod, 327 small block, TH350 |
