Old 09-01-2013, 12:10 AM   #1
donthekawguy
donthekawguy's Avatar
What front shock for 2 inch spring drop
I'm going with a 2inch lowering spring for now and adding 2 1/2 inch spindles next year. I need to know what shock I should be getting.
66 shorty
donthekawguy is offline   Reply With Quote
Old 09-01-2013, 02:37 AM   #2
donthekawguy
Re: What front shock for 2 inch spring drop
I just went to the brother site and they want $50 per shock. Also do I need the relocator kit with a 2 inch drop coil?
66 shorty
Old 09-01-2013, 10:29 AM   #3
boucher racing
boucher racing's Avatar
It all depends on your shock travel. If you can make a scribe line around the shock at ride height and measure your shock from eye to eye. Take that measurement and compare it with the compress/extended length the stock shocks show. via. rockauto.com....
Usually a 2 in. drop wont cause the stock shocks to bottom out.
If you do decide to really drop it. Read this post. Good luck
http://67-72chevytrucks.com/vboard/s...d.php?t=573266
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 09-01-2013, 07:00 PM   #4
AcampoDave
AcampoDave's Avatar
I believe relocators are for the rear only and needed when you go 4 or or more inches of spring drop. Well, 4" is borderline but probably a good idea to use 'em.
AcampoDave is offline   Reply With Quote
Old 09-01-2013, 07:30 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
They have the front shock replicators and those are really for structural integrity, thestickshock bolt tend to Waller the hole bigger. I also think you won't need drop shocks for a 2" spring drop.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-05-2013, 11:32 PM   #6
donthekawguy
Thanx guys! I might just go ahead and do the springs and shocks for this year. Any little bit helps. This winter I'll start stocking up on parts for the spring. I'm going to totally rebuild the front end and add power discs and spindles with all the other goodies. New shocks springs and shock relocators in the rear made a huge difference so can imagine how nice it will make the front ride.
66 shorty
