Old 09-01-2013, 02:29 PM   #1
plumber36757
Tailgate
What's the best way to put on and take off your tail gate. Is there a trick without removing the brackets.???
plumber36757 is offline   Reply With Quote
Old 09-01-2013, 03:59 PM   #2
chiefcfd
chiefcfd's Avatar
Re: Tailgate
No trick. You have to remove one trunnion then slide off the other side. If you want you can replace the trunnion from later model and cut a slot to remove.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 09-01-2013, 04:02 PM   #3
Sklptrljay
Sklptrljay's Avatar
Re: Tailgate
I don't know if it's the "best" way, but if you take off the bracket bolts from one side only, it will slide up until you can pull it straight out.
Definitely have a buddy there if you're concerned about scratching the paint.
Sklptrljay is offline   Reply With Quote
Old 09-01-2013, 11:15 PM   #4
pritch
pritch's Avatar
Re: Tailgate
Be glad they're a hassle to steal, with the crazy money a good one brings!
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
