Old 09-01-2013, 05:43 PM   #1
Recian
No power at accy in fuse block
So yesterday I was testing some connections on my radio. I was using the 1 wire orange pin connectors at the fuse block. I accidentally touched it to the dash trying to crawl out from under it. I noticed today my clock and overhead light don't work. They're both plugged into the "Battery accessory" plugs at the bottom of the block with the orange 1 wire connectors. Is there a fuse for that? It says battery + and the book doesn't list anything. Everything else on the truck works.
Recian is offline   Reply With Quote
Old 09-01-2013, 05:57 PM   #2
zaccaglin
zaccaglin's Avatar
Re: No power at accy in fuse block
The fuse marked Radio should be the one your looking for.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 09-01-2013, 05:58 PM   #3
Jaysonb
Jaysonb's Avatar
I just had the same thing happen last week. On my 79 the dome light is on the horn fuse. That is where I'd check first.
Jaysonb is offline   Reply With Quote
Old 09-01-2013, 06:01 PM   #4
Recian
But my radio works fine..
Old 09-01-2013, 06:05 PM   #5
Jaysonb
Jaysonb's Avatar
Check if the horn works.
Old 09-01-2013, 06:09 PM   #6
Jaysonb
Jaysonb's Avatar
If this is the orange wire your talking about, it should be the 20 amp fuse right above it.
Old 09-01-2013, 06:17 PM   #7
chengny
chengny's Avatar
Those 2 columns of BAT sockets are powered through (and proctected by) the 20 amp fuse labeled HORN/DIM.
It is the top fuse - just below the shunt - on the far left column of fuses.
Never mind the above that is for an 85+.
But on an 81, the BAT stabs are still hot through the 20 amp HORN/DM fuse
chengny is offline   Reply With Quote
Old 09-01-2013, 06:18 PM   #8
Recian
Success! Horn didn't work. Fuse blown. Clock works now Didn't know it ran off the horn fuse. Overhead light still no go but the bulb is dark so it's probably just blown. No big since pass. door is the only door that turns it on. Driver side has no switch just a big rust hole where a switch would be.
