Need lowering advice
Well, finally started to lower my 72 the correct way. Old springs were heated and poorly at that. I bought McGaugheys 2.5 lowered spindles and 2 inch lowered springs. All is good, except my tires are touching the inner fender wells. I have 255 70 15 tires all the way around. Im thinking of just getting a spring spacer one inch thick. Not really sure what to do. Spacer, different springs, or tire size change. Any advice. I love the height of where it is at right now.
Re: Need lowering advice
Get tires.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
You probably need to get a lower profile tire in the front. I have 2.5 drop spindles and 2" lower springs. No rubbing with 265/50/15. However, I'm going to change to 275/60/15 in front to gain some additional ground clearance. The 275s are only 1/4" wider than the 265s. The 60 series is 1.75" taller than the 50 series and won't rub.
1970 C10 Short Stepper with 71/72 front clip. |
Just had that thought and ran out to the garage and took the 255 60 15's off of my 87 and we have no rub. Thing that sucks is I just bought the 255 70's. Like always, all my good plans go to waste. The 255 60's are very low ground clearance, so I will look into the sizes you mentioned.
