Old 09-01-2013, 06:10 PM   #1
SCHRUMGMC
SCHRUMGMC's Avatar
Wiring Question
Alright my Back right brake lights don't show up and neither do the back Red side-markers..As I was looking under my truck I noticed a Red wire looked like it had been cut off
Help please !!!
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 09-01-2013, 07:43 PM   #2
JimKshortstep4x4
Re: Wiring Question
No red wires were used on the rear lights. There is a four wire flat harness going from the front to the rear lights. Light green: backup lights, dark green: right rear turn signal, brown: park lights, tag light, and trim light, yellow: left rear turn signal.
Brake lights work through the turnsignal circuits.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-02-2013, 08:45 AM   #3
midniteblues
midniteblues's Avatar
Re: Wiring Question
check too make sure the rear light assembly has a good ground.
check inside where the bulb goes too make sure the contacs for the bulb are present and not broken off.
i like too use a long wire that has alligator clips. one side goes too the battery ground.
take the lens off the light and sand/scrap a clean bare spot of metal on the light houseing. touch/clip the wire too the spot and test your light.
if it works you'll need to take the two screws out that are next too the bulb
and clean up the spot around the two screws where the back of inner light houseing touches/mounts too the bed. this is where the ground is.
of course you should have a test light. with it you can check the bulb socket too see if it even getting juice.if its not then you need too keep testing the wire.
the rear harness has connectors too the lights in the rear bed sides pull them apart an test.(if you do this they prolly should be cleaned up an greased anyway.
still nothing?
in the last frame crossmember theres round plug with the four wires that go through the metal. pull the rubber peices apart an test from here also.(jim pointed out witch wires too test)
if all else fails
buy some new bulbs
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 09-02-2013, 09:02 AM   #4
slow-1
slow-1's Avatar
Re: Wiring Question
still nothing?
if all else fails
buy some new bulbs
Start with the last suggestion first...burned out bulbs and fuses have cost me countless hours of troubleshooting over the years...you would think I would learn.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 09-02-2013, 09:05 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Wiring Question
Any time you can post pics with your questions,... it would be very helpful.
Keith
Convert to disc brakes.
Old 09-02-2013, 09:24 AM   #6
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Wiring Question
Alright I will today, I dont have anyway of getting the fuses out ?
1971 GMC Sierra
1959 GMC 100
Old 09-02-2013, 10:05 AM   #7
slow-1
slow-1's Avatar
Re: Wiring Question
They usually pry right out...use something non metallic...if they have been in there for 40 years they may be a little sticky, but the are just held in by thin metal tabs squeezing the fuse ends.
Old 09-02-2013, 10:13 AM   #8
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Wiring Question
But what if they break in there ?
1971 GMC Sierra
1959 GMC 100
Old 09-02-2013, 10:18 AM   #9
slow-1
slow-1's Avatar
Re: Wiring Question
Pull out the ends with needle nose pliers and put in a new one.
Old 09-02-2013, 02:17 PM   #10
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Wiring Question
Oh ok well that was simple, how do I know if my points are bad ?? It wants to start but it won't' and it cut off while driving it on me
1971 GMC Sierra
1959 GMC 100
Old 09-02-2013, 02:24 PM   #11
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Wiring Question
Your points are probably fine. Check/replace your fuel filter.
Tom Vogel is offline   Reply With Quote
Old 09-02-2013, 02:26 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Wiring Question
Lots of old trucks have messed up rear lighting because of prior owners hacking up the rear harnesses to wire in trailer lights and such. I've had to rewire the entire rear ends of trucks because of it.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-02-2013, 02:30 PM   #13
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Wiring Question
I just put a new fuel filter in there,,I wonder
1971 GMC Sierra
1959 GMC 100
Old 09-02-2013, 07:07 PM   #14
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Wiring Question
It may already be plugged. Is there crap in the tank maybe?
