09-01-2013, 06:55 PM | #1 |
Moving bellhousing x-member
Has anyone successfully moved a manual cross member forward during a I6 to 350 swap? I got my old one out and tried sliding it forward but the holes don't line up. After searching on this site, I discovered that 6 cyl. and V8s use different members. What are my options?
09-01-2013, 10:04 PM | #2 |
Re: Moving bellhousing x-member
1...get a v8 x-member...2...convert to an automatic,they don't use one....3...leave it where it is and install the engine back further(you wont have to buy a driveshaft)
1970 short step c10 leaf spring 454 |
09-01-2013, 10:36 PM | #3 |
Junior Member
We moved one forward when we put a 454 in a 69 frame. We had to trim a little off each end and then drilled holes in the frame to bolt the cross member in.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-02-2013, 06:54 AM | #4 |
I was considering doing the same thing, but drilling holes in the member, not the frame. Just seems like doing that would elevate the back of the engine. I am going to try to locate a proper member on the parts board while I ponder fabricating/modifying the old one.
09-03-2013, 09:14 AM | #5 |
Originally my truck was a 6-stick, then someone changed it to an automatic and torched off most of the bell crossmember.
I have replaced the 700r with a muncie m-20, installed a tailshaft crossmember/mount rather than fool with the bell member. IMO---much easier!!!
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
