Old 09-02-2013, 11:42 AM   #1
Tuff Gong
Tuff Gong's Avatar
under dash wiring question, please help
I want to start of by saying I know nothing about electrical. I'm was installing a new ac switch and radio when I noticed that there are some loose wires hanging out. I need help finding where they go. One is obvious, but I'm not sure if the double yellow wires go on top or bottom (where red arrow is). The other harness is a mystery to me. It may not matter too much because I have be running it as is with no issues.
Tuff Gong is offline   Reply With Quote
Old 09-02-2013, 12:25 PM   #2
swamp rat
swamp rat's Avatar
Re: under dash wiring question, please help
I believe the white multi pin goes into the back of the dash bezel but if thats not it it also looks like it could plug into the back of the radio that is not there..
Cant help you with the other plug.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-02-2013, 12:38 PM   #3
Tuff Gong
Tuff Gong's Avatar
thanks, after looking a little deeper I don't think the multi pin harness is original to my truck. The wiring is not that great, thanks to the PO.
Old 09-02-2013, 12:45 PM   #4
BBCK10
The double yellow wire plug is a 2 pin wiper motor.. Either way should work, just plug it in and test your wipers. The other white multi plug is for a stereo, black is ground/ red is battery/ yellow is ignition/ greens-blues-oranges-purples are to speakers. (as long as it was hooked up the standard way.)
BBCK10 is offline   Reply With Quote
Old 09-02-2013, 01:03 PM   #5
Tuff Gong
Tuff Gong's Avatar
thank you. so you live in sac. i was born and raised there. just moved about 3 months ago and miss parts of it already.
Old 09-02-2013, 03:42 PM   #6
Andy4639
Old member
Andy4639's Avatar
Cool Re: under dash wiring question, please help
As stated, white multi plug is for a radio. The other is for the wipers.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
