Old 09-02-2013, 11:49 AM   #1
Codez67Chevy
Codez67Chevy's Avatar
Canyon carving?
So I'm going to make my truck a daily driver. From driving to work, to going camping. I love taking canyon drives so I want it to carve through the canyons with no problems. Anyone got any tips on what I could do?
Suspension plans as far as now are....
3/4 coil drop
drop shocks
new sway bars front and back
new panhard bar
and that's it so far............
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 09-02-2013, 01:38 PM   #2
Ziegelsteinfaust
Re: Canyon carving?
I would move the lower A-arm forward in relation to the upper A-arm 1 inch. This gives you better camber gain.
Get a 1 ton swap bar, and use poly graphite bushings.
If you want to cut canyons try getting some 17's, and run SUV tires. A 255/50/17 will be a great all around tires. Just depends on how wide or tall you can accommodate.
Ziegelsteinfaust is offline   Reply With Quote
Old 09-03-2013, 10:04 AM   #3
SCOTI
SCOTI's Avatar
Re: Canyon carving?
Moving the lower arm forward yields better caster. Moving the upper down slightly vs. the lower yields the different camber curve.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-03-2013, 10:39 AM   #4
Custom 68
Custom 68's Avatar
Re: Canyon carving?
I just went thru all this. Here is my take on it as I just got it going and aligned this weekend.
First off I tried to move my lower a-arm forward and I could only move it forward 3/8 of an inch due to interference with the arm to the frame. So I am not sure how you can move it any more forward. I will do a search because I know many folks have recommended this. It may be different on different years but mine is a 68.
I also lowered my upper a-arm mounts 1/2 inch. I know that did help on my camber gain. I will get this on an autocross track and see the results.
good luck and if anybody has any other info on moving the lower a-arm that would be great.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-03-2013, 09:50 PM   #5
bdiamond
Re: Canyon carving?
On my 82 blazer I had not notch the crossmember at the ubolts. I cut the vertical lip off and ground just a hair off the horizontal part. I moved mine 3/4", I could have gone a hair more but already had drilled the shafts. I can send pictures if you need it.
bdiamond is offline   Reply With Quote
Old 09-04-2013, 11:53 PM   #6
66 C10 383
Re: Canyon carving?
Dave
Here's the "Caster Mod" where he moves his LCA forward .75".
http://www.67-72chevytrucks.com/vboa...ght=caster+mod
I've searched and can't find any good info on how the lower the UCA.
66 C10 383 is offline   Reply With Quote
Old 09-05-2013, 12:24 AM   #7
mongoose
mongoose's Avatar
Re: Canyon carving?
do you need to? these aren't f bodies?
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 09-13-2013, 10:43 PM   #8
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Canyon carving?
Do we need 500hp in a family sedan? Haha
I have mine 3/4 -1" forward I can't remember but I did some cutting of the crossmember. Have about 7.5* castor. Have qa1 adjustable ball joints so I can tailor camber gain and roll center
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-13-2013, 11:12 PM   #9
mongoose
mongoose's Avatar
Re: Canyon carving?
yes... and 500 hp wagons even more..
no, the reason i said that was that f bodies etc that people do the guldstrand mod to are cuz of the short spindle that they come with.. trucks have bigger spindles.. so im not sure that lowering the uca will net the same type of performance gain ie a better camber curve as an fbody gets doing it...
but i could be wrong i've never measured it nor seem any writing on the subject thus the question.
Old 09-15-2013, 06:55 PM   #10
cory d
cory d's Avatar
Re: Canyon carving?
my buddy did 1/2" with out trimming the cross member and with 2 coils cut on the one ton coils. the arms only hit the cross member when sagged all the way down but thats not an issue. no coil bind that i have seen. or i guess i should say coil rubbing on the edges of the pockets
cory d is offline   Reply With Quote
