Old 09-02-2013, 12:04 PM   #1
kijocoz
can anyone recommend a power brake kit
im looking to add a booster to my drum brakes(something bolt on) i bought a cheap kit on ebay but its 2ft long,hits my air cleaner and doesnt work. i should have asked here first. i am not looking to convert to disc just get a little more braking . thanks in advance for any help!
kijocoz is offline   Reply With Quote
Old 09-02-2013, 12:45 PM   #2
Pro Performance
Pro Performance's Avatar
Re: can anyone recommend a power brake kit
McGaughys makes a 7" and 9" booster for drum brakes. It does come with a new master cylinder as well.
7" Booster:
http://www.azproperformance.com/McGa...179-63180.html
9" Booster:
http://www.azproperformance.com/McGa...183-63184.html
Pro Performance is offline   Reply With Quote
Old 09-02-2013, 07:43 PM   #3
mixermike
mixermike's Avatar
So if a guy bought one of these boosters for his drum brakes and later decides to convert to disc up front will these boosters and master cylinder still work ?
Thanks, Mike
mixermike is offline   Reply With Quote
Old 09-02-2013, 07:50 PM   #4
Pro Performance
No, the drum master is specific to drum and has a little different specs than a disc master. It is best to match up the master cylinder to the front brakes you have. For example, if you have disc/disc and or disc/drum, then it is best to get a disc master cylinder.
Old 09-02-2013, 08:30 PM   #5
mixermike
mixermike's Avatar
Thanks for clearing that up for me
Old 09-02-2013, 09:00 PM   #6
kijocoz
will those bolt right on or do i need a bracket? the stock manual master bolts right to the fire wall.
