Old 07-06-2003, 08:10 PM   #1
lotik
drag it like you stole it
throttle pedal and cable assembly?
who makes one of these that would work nice in our trucks? i can't get my kickdown cable to work without one, so i guess i will go to a cable... any of you use one of these?
negative camber //LA\\
lotik is offline   Reply With Quote
Old 07-06-2003, 08:15 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Why can't you get your kick down to work with a throttle rod?
Whats holding you back?
Old 07-06-2003, 08:57 PM   #3
go-fast69
Mr. Gasket makes a throttle pedal & cable assembly that would probably work. I use one in my truck because the angle on my rod was too steep & kept binding up at WOT. It works great, dont know who makes it though, got it from a guy at work.
69 swb GMC, 402 BB, 3:73 posi, 3" exhaust, forever a work in progress
go-fast69 is offline   Reply With Quote
Old 07-06-2003, 10:41 PM   #4
Class of 69
Class of 69's Avatar
If you want a stock change over ...I have a complete assembly from a 72. $35.00 to your door.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 07-06-2003, 11:12 PM   #5
Longhorn Man
Does that include the firewall? They are not the same. I don't know what is needed to make the cable work on a rod fire wall though.
Old 07-07-2003, 01:32 PM   #6
lotik
well i had it rigged up but the trans still wouldnt kick down. so i figured it was because the rod was in the way of the bracket. i may need to just take the truck somewheres and get it hooked up, because i can't seem to get it to work.
Old 07-07-2003, 03:05 PM   #7
Locutus
Locutus's Avatar
what carb are you using
on my truck the kickdown cable is hooked to the carb. Also do you have a bracket to run the kickdown cable thru it should be mounted low near the intake so the throttle rod won't affect it
Mike
Locutus is offline   Reply With Quote
Old 07-07-2003, 10:00 PM   #8
Class of 69
Longhornmail...you need to make a square hole to accomodate the cable, and drill three holes for the bracket. Not a difficult upgrade. I can provide a cardboard template of the location of the square hole, and bracket holes.
