Old 09-02-2013, 12:31 PM   #1
swamp rat
swamp rat's Avatar
Chassie paint.
I'm rebuilding my front end, ball joints, bearings ect.
I've cleaned up the 40 years of grime and hit them with oven cleaner and a water rinse, if course they have flash rust now.
what should i paint the parts with? por-15 or some type of paint?
what should i do a final degrease or prep with?
Thanks!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-02-2013, 12:45 PM   #2
Fitz
Re: Chassie paint.
Thanks!
I bought the largest old oven I could find ($40.00) and powder coated the parts in the garage. The powder coating is a thermally activated epoxy that first melts onto the surface then hardens enough that you will never have stone chips. Just dip the parts in muriatic acid and rinse with water to be sure all of the rust is gone before you coat them.
Fitz is offline   Reply With Quote
Old 09-02-2013, 12:52 PM   #3
swamp rat
swamp rat's Avatar
Re: Chassie paint.
Well, powder coating is probably out of the question as i need to get this truck on the road soon. But i'd like to do it, there is a powder coating place about 15 minutes away from my house.
If i did have them do it would i have to remove all the studs from the knuckles ect?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-02-2013, 02:01 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Chassie paint.
Find some "Chassis Black" paint. It's usually a satin finish, so grease and oil don't show up as much.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-02-2013, 03:29 PM   #5
JD'S 69
JD'S 69's Avatar
Re: Chassie paint.
I used Eastwood chassis black. You can buy it in gloss or satin. You can buy it from Eastwood and also I am very happy with product...
JD'S 69 is offline   Reply With Quote
Old 09-02-2013, 04:49 PM   #6
GASoline71
GASoline71's Avatar
Re: Chassie paint.
Eastwood makes good stuff... but if you need it sooner than a few days... Dupli-color is what I picked up from the local parts store.
Gary
Old 09-02-2013, 06:32 PM   #7
468BIGBLOCK
MEMBER OF THE JUNK MAN CLUB
468BIGBLOCK's Avatar
Re: Chassie paint.
john deere blitz black. you can get it in a spray bomb.
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS..
468BIGBLOCK is offline   Reply With Quote
Old 09-02-2013, 11:39 PM   #8
Re: Chassie paint.
I use Dupli-Color engine paint in Low-Gloss Black. Same sheen as Eastwood's chassis black that they don't make,just market at 30% higher than the same stuff sold elsewhere. Engine enamel is tough stuff,too. For instance,I just painted some wheels I sandblasted with rallye wheel paint. Rather than pay $12.99 from Eastwood I got the paint from Corvette Central for $8.99. I figure if it's good enough for Vette guys it's good enough for me
Old 09-03-2013, 12:14 AM   #9
swamp rat
swamp rat's Avatar
Re: Chassie paint.
Thanks for the advice guys!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
