09-02-2013, 04:03 PM | #1 |
power steering conversion on a 292
has anybody done the power steering conversion on the 292 motor? im looking to see what water pump pulley is being used on it. i have a 2 groove balancer and need a pulley for the water pump. i had a 2 groove pulley but it did not line up right , so i need either a 2 or 3 groove to line up. if anybody no's which one i need let me no. thanks
09-02-2013, 07:14 PM | #2 |
Re: power steering conversion on a 292
I used CFV Racing. Buick 455 H2O pump pulley 2V. Check which H2O pump you have, you may have to drill new holes if you have a short noise or different year pump. There is probably a cheaper way to go. i remember having trouble finding the right offset pulley. Good Luck. Mike
Posted via Mobile Device |
09-02-2013, 07:47 PM | #3 |
its a stock water pump and a stock harmonic balancer. i need a two groove water pump pulley with the measurements - if you lay a pulley on a table with the mounting side down and the grooves up, then i need a measurment from the table up to the first groove center 1-11/16 and then the second groove center at 2-7/16, does anybody have one , thanks
