Correct paint finish for air cleaner?
I Swiss cheesed my factory air cleaner today- I drilled a bunch of holes on the backside and underneath to get better airflow through a stock looking unit. Then I spent a few hours wet sanding it to get it ready for paint. What can I use to get a good factory-like finish? I've got some rustoleum semi-gloss that I could shoot it with but want to know if the is anything that might look better. I didn't see anything at Eastwoods I liked. The first thing you see when you pop the hood is the air cleaner and I want it to look original. Any thoughts/ideas?
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
![]() Join Date: Jul 2012
Re: Correct paint finish for air cleaner?
I normally use good gloss black spray paint. I don't know if this is technically factory correct but it definitely looks original.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
1971 Chevy C10 Cheyenne (sold for Mazda) 1963 Chevy Corvair Pro-Touring Project 2012 Mazda 3 i Sport sedan http://www.dracoautodesigns.com/ |
Semi gloss flat black. They say that John Deere blitz black is very, very close to the original finish.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
![]() Join Date: Sep 2010
I think the "original" finish was a lot "glossier" then most people remember. Below, is a picture of that 70 C-10 with 80 miles that was for sale a couple of years ago. . . . the air cleaner and the exhaust tube DO have some gloss to them !!! . . . . |
I dunno... for 80 miles that engine sure looks aged. The air cleaner definitely outshines it.
#6 | ||
I've got some buddies with paint booths. I wonder if I could bribe them to spray it for me.... With the hours of sanding, it'd be a shame for me to mess it up. Maybe I'll revisit delmo's engine pics. He's inspired me to paint my block the body color (medium blue) and the rest in black. That looks so sweet on his builds.
SWB 4x4 Collector
![]() Join Date: Jun 2001
The air cleaner is definitely more gloss than the chassis and underhood black. It carries over into the muscle car restoration as well. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#9 | |||
I found this on an olds forum where they were discussing the same thing... http://www.rickscamaros.com/1968+che...oss-black.html (product discontinued though- bummer). I know I'm way overanalyzing this but if I can't work on the truck (working out of town), at least I can research stuff... added: found this on a corvette forum. I think I'll see if I can find it.... Buy a can of "Plasti-Kote..... T3 - Hot Rod Black". Its a lacquer / high heat resistant coating. I swear by this stuff, and it pass's NCRS judging as well. Heat the part to remove the moisture held within the metal....either an oven bake or small torch. Apply a light coat or dusting to all the hard to get to area's first. Let it dry, and then come up from there. Two coats should be more than enough.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 Last edited by NC_John; 09-03-2013 at 09:31 PM. Reason: added - plasti-kote info |
#10 | |
SWB 4x4 Collector
#11 | |
![]() Join Date: Sep 2012
I used a flat black. I don't know what exact paint. It was something my neighbor had in his gun at the time. Then I shot it with satin clearcoat.
I left my inside unpainted and just cleared it as well. End result matched up to my new GM valve covers. |
#13 |
Cluster King
![]() Join Date: Nov 2012
I don't have a photo now but Dupli Color gloss black engine enamel works great and has just the right amount of gloss. It looks like chassis black.
#14 |
chrome makes it run better i think
#15 |
![]() Join Date: Jun 2012
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
#16 |
![]() Join Date: Oct 2009
I've used Eastwood gloss chassis black, goes on well, appears to be correct gloss, and, most importantly, it's very durable.
Posted via Mobile Device |
#17 |
My Harley is decked out with chrome... I want to keep the truck simpler with no chrome under the hood.
