Old 09-03-2013, 07:17 AM   #1
R_W
R_W's Avatar
Radiator for '63 C50?
Anyone know a good source for a radiator for a '63 C50? I have relative that uses one for a water well rig, and he just blew the radiator. Cost matters in this instance.
______________________
"Daddy, that truck's not red"
Build Thread: TN 20 Build
R_W is offline   Reply With Quote
Old 09-03-2013, 07:34 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Radiator for '63 C50?
What size motor?
I use a champion aluminum radiator made for our trucks. I got mine from Reliable radiator and they are warrantied for life. not expensive either.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-03-2013, 09:52 AM   #3
R_W
R_W's Avatar
6 cylinder but I don't know the size.
Old 09-03-2013, 04:02 PM   #4
Clyde65
Clyde65's Avatar
I vote for the Champion, you can paint it or leave it shiney!
Clyde65
Rebuild of Clyde
support our troops!
Old 09-04-2013, 01:18 AM   #5
Captainfab
60-66 Nut
The C50 will have a much larger radiator than a light duty truck. I am not aware of a source to get one like the factory one. You may have to get an aftermarket or original radiator for a '60-'62 C10-30. With the I6 it should cool just fine unless you are working it real hard. Another soruce for a radiator that will work is the '67 and earlier Chevelle, Malibu, Impala, Caprice
Old 09-14-2013, 09:31 AM   #6
SparkyRnD
SparkyRnD's Avatar
we make bolt-in radiators for the 63-66 Chevy trucks, not sure if the C50 would be the same size or mounting. here is a link to them on our site:
http://www.rndfabrication.com/C10early.html
Let me know if you think it might work. It's made to be a bolt-in direct fit swap, no cutting / welding / modifying.
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 09-14-2013, 10:41 AM   #7
63burban
Chevy addict
I use Speedway radiators, just need to make an upper bracket and something for it to sit on the bottom. The radiator costs $129 and work great
http://www.speedwaymotors.com/Speedw...tors,3557.html
Item #:
917347
63burban is offline   Reply With Quote
Old 09-14-2013, 10:57 AM   #8
Bigdock
Originally Posted by Clyde65 View Post
What size motor?
I looked them up I couldn't find anything made for our trucks would you happen to have a link or a part number for it thanks
Bigdock is offline   Reply With Quote
Old 09-14-2013, 01:01 PM   #9
66Submarine
66Submarine's Avatar
Item #:
917347
I have one of the speedway generic aluminum radiators too, very nice and the price is certainly right. Thick inlet/outlets, the welding was nice, and no BS epoxy.
66Submarine is offline   Reply With Quote
Old 09-15-2013, 12:41 AM   #10
Captainfab
60-66 Nut
As I said above, the radiators for the C40 and bigger trucks are bigger than the radiators for the C10-30's. They are about half again the size and mount directly to the radiator support. There are no lower and upper cradles for the radiator to sit in.
