09-03-2013, 09:27 AM | #1 |
AC Retrofit
I am changing over my R12 system to R134a. My system has not worked since I got it and the hoses are cracked. My question is does anybody know what kind and weight of oil to use. Also how much oil is needed?
09-03-2013, 10:26 AM | #2 |
Re: AC Retrofit
First thing you need to have someone vacuum out the system you can't just throw some oil and refridgerant in it and expect it to work. You should also change your dryer and the high and low pressure fittings. To do it right you should also change the compressor but can get by without that. I spent almost $800 to get mine working the way I wanted, Good Luck. John
69 Chevy 4x4 383 Power |
09-03-2013, 10:37 AM | #3 |
Re: AC Retrofit
Actually the first thing you need to do is flush the system clean. I know all the steps. I have the new dryer and fittings. I have the flush kit and flush for the condenser, evaporate, etc. I have drained the oil out of the old compressor as best I can. I will barrow a vacuum. I have the pressure gauges. Just need to know the oil weight and volume.
09-03-2013, 01:01 PM | #4 |
Re: AC Retrofit
In my experience you will blow the front seal out of a used compressor in a short amount of time. I would pony up now for a compressor.
I don't have the shop manual in front of me, but the info you seek is in there. If you don't have a factory shop manual, I would highly recommend getting one.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
09-03-2013, 01:12 PM | #5 | |
Re: AC Retrofit
Most, around here, will recommend ester oil for a retrofit. I believe it only comes in 100 VI IIRC, the amount for the pickup is 10 ounces.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
09-03-2013, 01:17 PM | #6 | |
Re: AC Retrofit
http://67-72chevytrucks.com/vboard/s...d.php?t=478564 The compressor I'm using is a stock compressor off of a 1971 Monte Carlo. I've heard a lot about compressor failure but have yet to experience it. Make sure you adjust your POA to work with R134a.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
09-03-2013, 01:28 PM | #7 |
Re: AC Retrofit
Thanks for all the info.
