09-03-2013, 11:59 AM | #1 |
TH350 Slipping???
Hey guys, I have a TH350 behind a 400 small block in my 72. It feels like the tourqe converter isnt working correctly, but i have to give it some gas to make it move forward or backward. almost like i have a clutch and im letting it off slowly. Just wondered if you had some advice for me. Thank you in advance.
09-03-2013, 12:16 PM | #2 |
Proprietor of Dale's Corner
Re: TH350 Slipping???
First check the fluid and make sure it's full
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
09-03-2013, 12:19 PM | #3 |
Fluid Level is fine
09-03-2013, 12:20 PM | #4 |
Is this something that has just started to happen?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-03-2013, 12:21 PM | #5 |
It has done it since i have owned it
09-03-2013, 12:22 PM | #6 |
Does it have a stall converter? Once driving how does it shift and Feel?
09-03-2013, 12:23 PM | #7 |
Havent actually had it on the road yet, have taken it down the pasture road and seems to shift up and then immediately shift back down.
09-03-2013, 12:27 PM | #8 |
What speeds on the pasture road? May need to get in the service manual and follow the pressure check sequence. It may have a stall converter you don't know about possibly.
09-03-2013, 12:39 PM | #9 |
Speedo said 30~ very well could be a stall converter. Will follow pressure check procedure.
Posted via Mobile Device |
09-03-2013, 12:42 PM | #10 |
I'm leaning towards a stall
09-03-2013, 01:25 PM | #11 |
Alright, is there a way to fix that, or do i need to just buy another converter?
09-03-2013, 02:07 PM | #12 |
Another converter
09-03-2013, 02:42 PM | #13 |
Copy that, thanks for the advice guys.
