Does any one knows where I can buy these kind of connectors, I am looking for the 6 connectors, I was able to find the female plug, but I need the male plug. I am trying to wire the whole truck and I want to use the same kind of plugs.
Here is a picture of the male plug ![]() Here is the female plug from my truck ![]() Thank you for your help |
Re: Delphi 56 Series Connectors
Standard brand hp7110 and hp7120-about 5 terminal each pack.
Thanks 64fleetside, I am doing a search and having trouble finding them, do you have a website where they sell them.
Thanks again. |
![]() Join Date: Jan 2011
Thanks T Smith, I try that webpage but they do not have the male connection, they only have the female connection
Junior Member
![]() Join Date: Feb 2013
Napa auto carries them. They're listed as Wire Terminal/OE Terminal
part number: NW 725447 |
chevyJr, thanks, that is the actual metal connector, I am looking for the actual plastic enclosure, I am sorry for not been specific that it was the plastic plug.
Thanks |
Active Member
![]() Join Date: Aug 2012
If you don't mind not using the factory terminal configuration. Check out this link. You can buy both sides for a 6 pretty cheap.
http://www.waytekwire.com/wps/portal...P&mfg=45&sc=19 Last edited by Gary V; 09-03-2013 at 03:15 PM. |
American Autowire had them in their classic update kits. Maybe they would sell you just the plastic shells.
60-66 Nut
![]() ![]() Join Date: Mar 2007
