![]() Join Date: Feb 2003
Head in the clouds, seat problem, help?
hello everyone. i have a problem that you all might help me with.
i just had my factory seat for my 1972 cheyenne re-done, down to the frame, both new seat foams, cover, and when i installed the seat i found that when i get in my head is aprox 1" from the roof and the steering is 1" from my (beer belly). and im only 5'11" in height. i didnt notice this problem before but im sure the original seat after 45 yrs had sagged. anyway i cant drive this truck that way.whats a good fix? i have collasped the steering column to solve some of my "too close to the wheel" problems. but still have the height problem. H E L P ! ***and has anyone else ran into this problem? poss fix.... *-- does any othe year (1967-71) seat sit lower? *-- can i cut down the brackets?
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
Re: Head in the clouds, seat problem, help?
Can't believe your seat was stock to begin with if you are 5'11. I am 6'3 and head room is fine. But in answer to your question your best bet is to pull the seat and mod your brackets to lower the seat. But you can only lower until it rides the floor tunnel rise. Might pull the seat you have and post a pic maybe someone swapped the seat brackets on you at some point and you can hunt some stock brackets for your seat??
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
sun roof?
"Negative people always seem to have a problem for every solution" |
![]() Join Date: May 2012
haha.... that made me laugh a little. Do you have any pictures of the problem?.
Garage Built |
![]() Join Date: Sep 2010
The same thing happened to me after my seat was "redone" ten years ago. That new seat is very FIRM. That old foam must have been at least an inch and a half lower !!! My arm can't even reach the armrest anymore, it's too low !!! LOL I just bought an original type cloth and vinyl seat cover and I'm going to have it redone again this winter. ( this time, the foam is going to be a little lower ) . . . . |
#6 | |||
hehehe, good idea! Quote:
![]() Join Date: Apr 2012
I built custom brackets. Lowered my seat 3". I never liked sitting that high up, felt like I was driving a tractor.
If you're interested, I can send you some pictures of what I did. You could drop as much or little as you want.
I'm 6'4" 240 and I have alot of head room and not much leg room.
I'm not as good as I once was, But I'm as good once as I ever was. |
I'll be getting my seat recovered before too long and never considered this....
Being 6-6" myself, this is something to think about too! I can't imagine losing MORE space in this little cab....
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
Petroleum User
I bet the leg room improved though. That's what ii wish I had more of with my saggy bench seat
![]() 1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
Cluster King
![]() Join Date: Nov 2012
I know exactly what to do. Is it black or parchment? If so, I will trade you for my seat which has the sensation of setting on a bean bag.
#13 |
My mind tells me the foam is too thick. Was it store bought pre-made foam or did the shop "make" it? The only thing that doesn't add up with this is if the foam is thicker than OEM then how would the "made to fit OEM style" seat cover fit? Those cheapo LMC Cheyenne covers don't even fit over old foam right...been there/done that
#14 |
2WD Jimmy
![]() Join Date: Mar 2005
Pics?
#15 | ||||
i will take a pic tonight and post it tomorrow. i did notice that the jute under the carpet is taking up about 3/4 of an inch. the back of the seat is about 1" higher than the bottom of the back window. so im thinking i can drop about 3/4" if i cut out the jute under the carpet.
#16 |
well i cut down the seat brackets down 2 1/2 " and got my head out of the clouds. but still feel too close to the dash! feels like the seat is slid all the way foward! foam is very firm.
no give at all.... pics
#17 |
You are not the only driver with headroom and legroom challenges.
I am 6' 6" tall and my head nearly hits the roof on both my '69 GMC 1500 and my '70 CST. I am glad the CST doesn't have the extra tinting at the top of the windshield so I can see the road. (The GMC has the tinting and I have to adjust for that when I drive.) The GMC is the bare bones model without any roof liner so I get a bit more head room in that truck. Both trucks have the original stock seats in them and both seats are in like new condition. Both trucks list "Full Foam" on their SPIDs. Maybe the non full foam seats had more span to their headroom and legroom. I am more careful than most when I hit a bump in the road. I am interested in lowering my seats somehow. I will look into adjusting the seat brackets. |
#18 |
i cut my seat brackets down 2 1/2 " that solved my headroom problem. now ?? ...re-foam the seat back?
#19 |
Do you have any photos of how you cut down the brackets? I think this is my next step.
#20 |
took no photos, but i just cut down and welded one at a time so i could line up the mounting holes with the other. hope it helps? dave
