Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Pre 1947 Chevrolet & GMC Parts Board
Old 09-03-2013, 04:09 PM   #1
runningiron
runningiron's Avatar
Closed to Open Driveline Conversion Bellhousing
Selling a 1948-1953 GM bellhousing casting # 3835201 modified by Buffalo Enterprises to convert your closed driveline in a 1931-1947 Chevy 1/2 ton truck. It allows you to use your existing clutch pedal shaft to the bellhousing. It also enables you to use a modern syncronized 4 speed trans out of a 1948-1964 Chevy truck, car Saginaw 4 speed or a Chevy S-10 5 speed. You will have to change your rear axle from a closed to an open rear axle.For purposes of description, it is the same bellhousing that Jim Carter sells under part# REME570. It is unused since modification from Buffalo Enterprises. I'm asking $100 plus shipping. Call Bob at 520-705-7769 or email me at rnmcole@msn.com SOLD
runningiron is offline   Reply With Quote
