09-04-2013, 03:54 AM | #1 |
Crossmember
I don't want to z the frame can a crossmember be built
Posted via Mobile Device |
09-04-2013, 10:32 AM | #2 |
67-72 parts collector,…
Re: Crossmember
Sure,... but I don't have the engineering knowledge to do it.
The Porterbuilt Dropmember is the perfect example of a "bolt-in" crossmember design that has been perfected by board member/vendor Nathan Porter. I think your REAL question,... is there a CHEAP way to building your own crossmember. I say NO to that. Some say a frame "Z" is the cheap alternative. But they create their own issues.
09-06-2013, 05:18 AM | #3 |
Re: Crossmember
Is this the latest version? Whats with those control arms? Waterjet?
09-07-2013, 06:52 PM | #4 |
Re: Crossmember
They look to be Michigan Metal Works flat plate arms
09-07-2013, 06:52 PM | #5 | |
Re: Crossmember
The porterbuilt unit as posted is a great product and tons of them are on the roads. |
09-09-2013, 02:39 AM | #6 |
Re: Crossmember
You can't go wrong with Porterbuilt or scotts hot rod shop http://www.scottshotrods.com/6387clip.asp no limit has a ifs kit too http://www.nolimitparts.com/prodinfo...umber=WRIFS3-C
09-14-2013, 10:55 AM | #7 | |
Re: Crossmember
You have to plan everything correctly and ensure you make your cuts in a very precise location, especially in the front because of the steering box location. If you go more than 1.5" on your "Z", you will have to make clearance on your driver's side upper control arm for the steering shaft. If you don't have a high-hump cab, you may have to do some cab floor mods for clearance. I have a high-hump cab, and I went up 2" on my "Z", but went down 2" on the engine/trans engine mount stands to ensure that the fan and shroud would line up, but I still had to do some mods because I had a late-model serpentine belt system. I had to go from the stock late-model 19.5" clutch fan down to an 18" fan and do a bunch of surgery on the fan shroud. I wound up sectioning 2" out of the inner fenders and reattaching the bottom lips because I wanted it to all look factory. I could have saved myself a ton of work by going with no inner fenders, an electric fan, and a new trans tunnel, but I want people to not see all of the work that was done, and just think that it was all factory. lolife99 is right. Each way has it advantages and disadvantages. A Porterbuilt set-up is going to cost a lot more money up-front but will require less "over and above" mods on the shroud, linkages, and inner fenders to make it work. A "Z" is the exact opposite. Much less money up front, but much more labor afterwards if you want to do it right. Believe me, I went back and forth on this for a long time. My thrifty side prevailed in the end.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
