Old 09-04-2013, 05:44 PM   #1
WEBBY1
WEBBY1's Avatar
drop spindle question
I bought a 65 burban that has crappy air suspension.. question is ... when I do my disc conversion will a 3" drop spindle be to much?
WEBBY1 is offline   Reply With Quote
Old 09-04-2013, 09:10 PM   #2
1rudestude
Re: drop spindle question
do not buy anything over 2 1/2 drop they will not mess up the geometry of the suspension and if you wont to go lower use springs to accomplish that.
1rudestude is offline   Reply With Quote
Old 09-05-2013, 12:58 AM   #3
WEBBY1
WEBBY1's Avatar
it has full air ride. thanks for tip
Old 09-05-2013, 02:22 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I've used 2.5" and 3" drop spindles for years.
Either one will be fine.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 09-05-2013, 07:43 AM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
depends on your wheel choice IMO.
larger wheels will work great with either, 15"X 8" wheels will rub on both but you can trim the LCA to work on the 2.5's or you can run 15X7" fronts like I do.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-05-2013, 08:12 AM   #6
T Smith
T Smith's Avatar
I'm running 15x8's on 2 1/2" drop spindles and didn't trim anything, depends on the backspacing.
T Smith is offline   Reply With Quote
Old 09-05-2013, 12:59 PM   #7
lolife99
lolife99's Avatar
correct.
Keith
Old 09-05-2013, 01:54 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
2.5 and 3 inch drop spindles lower the advertised amount without affecting anything negatively. It's just a matter of which brand you choose and what configuration the manufacturer chose. I usually choose 3 inch if there's one for my application because its a free half inch of drop gained over 2.5 without having to take the height out of the springs.
Then its a matter of choosing a wheel with a moderate backspacing to clear the control arms. I just built a truck with 3 inch spindles, 2 inch springs for a total of 5 inch front drop and have no rubbing anywhere and needed no trimming anywhere. It's all about the backspace. In my case, a 6 inch front wheel with 3 inches of backspace.
Old 09-05-2013, 02:31 PM   #9
T Smith
T Smith's Avatar
My 2 1/2" spindles came from POL and I'm 99% sure the back spacing on my 15 x 8's is 4.5".
Old 09-05-2013, 08:31 PM   #10
gimmy 64
my truck has 2 1/2 spindle and 2 in. spring with 15x8 wheels 4.5 backspace no problems
gimmy 64 is offline   Reply With Quote
