Sound Deadening These Old Rattle Cans...
Folks, once again I call your vast experience and and knowledge
I am in the planning and hoarding stages of my CCLB build. Its soul purpose is going to be a DD/work truck, this wont be a trailer queen. While riding around in a 06 Chev Dmax today (test drive), it dawned on me that this is the truck I am modeling it after in the back of my head. I am using the drivetrain (hence the test drive), seats and likely the dash. I want every thing in this truck, just in a sqaure wrapper (i haver a way of choosing the hardest route to do things) Now my concern is, can these old squares be made to ride as quite and comfortable as new vehicles? I don't mind spending good money on good product and i understand it wont be 100% but i want close. Now im talking smooth ride, i am strictly talking about road noise and highway comfort I have no experience in sound deadening and hear great things about second skin and such, but i want to know just how close I can get. Thoughts and comments are greatly appreciated, Thank you Scott
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims. |
Re: Sound Deadening These Old Rattle Cans...
I used Second Skin Damplifer Pro On my crew on the doors, floor, and roof. It made a huge difference, cost was about $900 dollars but I feel it was worth every penny I was pretty impressed with their product .
Someone on here did their crew cab... Think it's dieseldawg142? Could ask him how his was. He used MLV in everything and fat mat.
http://67-72chevytrucks.com/vboard/s...d.php?t=559596 Found it!
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 Last edited by 79Betty; 09-04-2013 at 08:01 PM. Reason: Found the Link |
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
Cascade audio is one of the best for sound deadening. Also a company called Sound Deadener Showdown. You'll be spending a good bit of money like that one member said, close to $1,000 to do the job right.
I used Dynamat and love the results, I have never used anything else.
Don't Crush em Restore em
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
Awesome.
Thanks for the insight gentlemen. I will do research into the product but the general consensus seems to be that i can get this truck close to if not above and beyond modern standards. Your comments are Much appreciated Scott Posted via Mobile Device
All you need is some injectable foam, mass loaded vinyl, and peel and seal (home Depot)
Posted via Mobile Device |
#10 | |
Just trying to manage your expectations... Posted via Mobile Device
1972 GMC Sierra Grande (current truck) 1980 Chevy Stepside (gone) 1987 Chevy Blazer (gone) 1972 Chevelle SS Convertible (gone) 1973 Chevy Corvette (gone) 1967 Chevy Camaro (STOLEN!) |
#11 | |
I've used FatMat and Lowes/Home Depot peel N Seel, both work pretty good. For a higher budget build, I've used FatMat and for low buck build( which most of mine are), I've used peel and seel with very good luck and results. |
you do realize most the companies use an injectable Foam In their cars and trucks, if you have a leak it will hold moisture
#13 |
Injectable? How?where? Elaborate
#14 |
https://www.youtube.com/watch?v=V3zA...e_gdata_player
#15 |
We mainly used them to stop two panels from vibrating again each other because the bass would cause heavy vibrations
#16 |
Is peel and seal that roof stuff? If so, is it asphalt based? Do not use asphalt based stuff in your truck. Especially if you live in an area where it gets hot. Very bad idea
#17 | |
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#18 |
I used Dynamat Extreme on the floor and firewall but ran out and didn't do the back wall of cab or the doors. Road noise is the same as without the Dynamat.
What is this peel-n-seal stuff exactly?
#19 |
Cheap roofing repair stuff you can get at home depot. IIRC, its similar to the construction of the sound deadeners because its got black goop attached to an aluminum backing. Why I'd never use it:
1. I'd be willing to bet its asphalt based. That stuff melts a little in high heat, and its enough for it to start showing up in the seams of your carpet. Where it meets the panels and such. Seen that personally. 2. Do you like the smell of a new blacktop parking lot in high heat? Your truck's interior will now have that smell if you live in an area (like the south) where it gets hot. 3. It was never made for this purpose, and as such the aluminum is very thin. The good ones, like Dynamat Extreme for example, employ a much thicker (relatively) aluminum backing. This is the key element in "blocking" the sound as it adds the necessary mass needed to dampen the resonance of the metal. Your metal is basically vibrating as you're rolling down the road, and the thicker aluminum just won't jiggle as much and thus your metal doesn't get to make any noise. That roofing stuff was never intended for this purpose. Your best bet is just cough up a few more bucks and do it right. |
#20 | |
#21 |
I used fatmat in mine along with a new carpet kit that had the jute padding on it. Although not as quite as a new car, there are places I can improve on, it is much quieter and a normal conversation can take place.
#22 |
Also, don't forget that a quiet exhaust is one of the keys to a quiet ride.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
#23 |
#24 |
I used some of the peel and seal stuff I got at Lowes. Wasn't the aluminum backed type. It was rubber sheet with adhesive on the back. I think GAF made it. As far as the injectable foam goes, most are thinking of the Great Stuff type of foam. I believe it dries as an open cell foam. I have a truck that was used in. Yes it holds moisture. That's why it's named Rusty. I don't really like the factory foam either. GM did it in the 70's in quarter panels, etc and it created an awful lot of rust.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
#25 | |
So far a faint odor is there, keep in mind I don't have a carpet yet so its just that stuff in there. Waiting it out to see if it gets worse or not.....
1966 C10 250 with 3 on the tree Build Thread Bunch of other cars no one cares about
| Bookmarks |
