Old 09-04-2013, 06:26 PM   #1
jmader
jmader's Avatar
1967 GMC V8 Engine qestion
Could anyone tell me if a 1967 4X4 truck has a partial VIN stamped on the block by the engine code? I've read conflicting things. My VIN is pretty low if that might make any difference.
jmader is offline   Reply With Quote
Old 09-04-2013, 06:29 PM   #2
jmader
jmader's Avatar
Re: 1967 GMC V8 Engine qestion
The engine I have in my truck is not the original so I am going to be looking for a replacement
Old 09-04-2013, 07:48 PM   #3
Bigdav160
Bigdav160's Avatar
GM started stamping partial VIN's on the pad, in some car lines, around 1960.
In the late 1960's Congress was pressing manufactures to put identification numbers on engines to cut down on theft.
In my readings, trucks did not get partial VIN's until much later.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-04-2013, 08:59 PM   #4
Keating121
Keating121's Avatar
Some good info here on engine codes. http://www.nastyz28.com/sbchevy/sblock.php
8/24/13 First Classic Truck
'67 Short Fleetside, Candy Apple Red! 350ci, Holly 750 double pumper (too much, will change soon), Headers with FlowMaster exhaust, 700R4 tranny.
Keating121 is offline   Reply With Quote
Old 09-04-2013, 09:19 PM   #5
jmader
jmader's Avatar
Yeah the Nastyz28 website is very helpful in identifying engines. I guess my real question is does anybody actually own a 67 with an original engine that could tell me if their vehicle has the VIN stamp anywhere?
Old 09-04-2013, 09:30 PM   #6
71swb4x4
71swb4x4's Avatar
Everything I have read indicates that a partial VIN was not stamped on 1967 truck engines.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-04-2013, 09:53 PM   #7
The way I understand it,from '60 till late in the '67 production,no GMCs got V8s. The VIN would be a KE VIN. What is your engine code?
Old 09-05-2013, 12:01 AM   #8
Keating121
Keating121's Avatar
Nope, sorry. My 67 has a 70 or 72 (Same suffix, TAX) 350 block 0010...
Old 09-05-2013, 06:49 AM   #9
jmader
jmader's Avatar
My VIN is KE15XXXXAt some point someone put a 350 in it and there's no SPID so I don't know if I'm looking for a 283 or 327 to replace it. It has a 4 speed.
Last edited by jmader; 09-05-2013 at 11:08 AM. Reason: I don't want to display my full vin #
Old 09-05-2013, 07:29 AM   #10
jmader
jmader's Avatar
Re: 1967 GMC V8 Engine Question
I'm probably going to be looking for a 327 with engine code YS. Does anyone know what the A.I.R. option is?
Old 09-05-2013, 07:50 AM   #11
I wouldn't ask for a VIN to be posted here. Just wanted to establish if your truck was in fact a KE model,which is 4wd V8. The VIN tells nothing specific about an engine. The suffix code (letters at end of stamped engine number) does,but you are working from the other end since you know you don't have the original engine.
WB,WI,or WO would be a 283 2bbl w/manual transmission 175hp
YM would be a 327 4bbl w/manual transmission 220hp
At least some of these codes can be found on other trucks with different ratings,but these are the codes that would be on an engine that came in your truck
Old 09-05-2013, 08:34 AM   #12
jmader
jmader's Avatar
By no means do I think you we're trying to get a VIN out of me. I just wanted to show that this is in fact an early run V8 because I've also read that the V8's didn't get released until later in the year. Thanks for the engine code info. That will help me immensely. I'm guessing it probably originally had the 283 because besides the 4X4 this truck had almost no options on it.
Old 09-05-2013, 09:36 AM   #13
bruceman1968
bruceman1968's Avatar
jmader, just wanted to suggest that you X out the last 4 numbers of the vin in post 9. Those numbers are your serial number and they are unique to your truck. The other numbers and letters (except the assembly plant code) can be figured out just by looking at the truck. So the numbers you should guard are the serial numbers and the assy plant code. Here is a 67 gmc, USA built, VIN Number decoder, so you can see what I'm saying.
EDIT: Also edit the number in post 1 (#XX)
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 09-15-2013, 06:54 PM   #14
jmader
jmader's Avatar
Do you know what the difference in the WB, WI, and WO engine codes are? Does production date have anything to do with it? I found an engine with the code WI but its very late in the year (November) The engine code is correct but the date would be way off for my truck.
Old 09-15-2013, 07:10 PM   #15
bruceman1968
Hope this helps
WB = 1967 283, 1968 307, 1969 350
WI = 1965-67 283, 1968 307, 1969 350
WO = 1965-67 283, 1968 307, 1969 350
