09-04-2013, 07:40 PM | #1 |
heater core
New to the site, so hoping for some help. I removed an old heater core from non-ac 67 C10. I installed new exactly the way the old came out (even took pictures), but now realize it's probably upside down. The 5/8" tube is now on top and 3/4" on the bottom. I think it was reversed from the factory. Will it make any difference, so long as I properly route my hoses? I would route 5/8" from intake to 5/8"tube on core (now on top) and 3/4" from water pump to 3/4" tube on core (now on bottom). I read elsewhere that someone had reversed theirs on purpose to avoid the crossing of the hoses. Hopefully I put this thread where it belongs, if not, would someone please let me know. Thanks for the help.
09-04-2013, 08:07 PM | #2 |
I am a Referee of life.
Re: heater core
That's how it was from the factory.From what's been discussed on this site,GM wanted more hot going into the bottom with a restriction(smaller outlet) to help keep it from getting air and making noise.I turned mine over but that was to get better hose routing.The hoses on the fatory mounting direction cause the hoses to cross.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-05-2013, 01:57 PM | #3 |
Re: heater core
Has the heater worked ok in the upside down position? Any noise that you mentioned? Seems to me that unless something in the heater core is directional that it wouldn't make much difference. Hot water still makes it to the core.
09-05-2013, 03:20 PM | #4 |
Re: heater core
It makes no differance. I have had mine that way for two years. No problems
09-05-2013, 09:10 PM | #5 |
Re: heater core
Yeah,mine works fine but I do get"You know your heater core is upside down,don't you?"
09-05-2013, 09:25 PM | #6 |
Re: heater core
Thanks for the responses, I appreciate it and the fact that now I don't have to create more work for myself by turning it over. I too think the hose routing is better in this position. Gets cold here in MO, so I didn't want to reduce heat to the cab.
09-05-2013, 09:38 PM | #7 |
Old member
Re: heater core
The heater core has no directions on it that I have ever seen. Most engineer's will tell you to fill it from the bottom so all the air is pushed out. Other than that it doesn't care.
09-05-2013, 09:46 PM | #8 |
Re: heater core
How hard was it to replace your heater core ?
09-05-2013, 10:00 PM | #9 |
Old member
Re: heater core
If you have heat only it's not as bad as AC.
But no matter which I would drop the passenger fender down. Here is a link. http://67-72chevytrucks.com/vboard/s...d.php?t=459357
09-05-2013, 10:03 PM | #10 |
Re: heater core
Thanks for the link ,I think that is in my future ,my 1 ton heater core has been bypassed so I assume its bad.
09-06-2013, 09:03 AM | #11 |
Re: heater core
I was doing a motor replacement so I already had inner fenders removed. Still had to remove passenger side hood hinge to remove heater box. Actual replacement is easy, IF you get a good core replacement. Bought one from LMC which was nowhere close to original dimension and didn't include brackets needed to hold it in and originals won't fit over their core; too thick. Returned it and got another from Classic Parts, which was nearly identical to original and the original brackets did fit. Oddly, neither company provides the brackets so take care not to break them. Aftermarket gasket sets are not the best but if you take your time, they'll work.
