09-04-2013, 08:21 PM | #1 |
Prothane Cab Mount Question
So I'm finally to the point of setting the cab back down on the frame - big day - I had picked up some prothane cab mounts - I expected to drop these down into the holes in the frame but the diameter of the raised piece doesn't fit down into the holes - am I missing something?
This raised portion should fit down into the hole in the mount right?
64 Step Side - The Mistress |
09-04-2013, 08:41 PM | #2 |
Re: Prothane Cab Mount Question
Wish i knew, i have the same ones...hopefully someone can help us out here. Subscribed!
09-04-2013, 09:00 PM | #3 |
can you ream the holes larger to accept the new mounts,? you got to love the after market but without them these trucks would be harder to build.
04-12-2015, 10:27 PM | #4 |
I bought the prothane kit about 3 years ago never installed them. I was able to mount the cab but the RAD mounts don't fit the frame are smaller then the bushings like you had. I was thinking about drilling them out but worried it might throw off the fender alignment. Did you ever get them to fit?
