Old 09-04-2013, 09:26 PM   #1
BurlyCrew
How can I identify the sheet-metal on my truck as being OEM or Reproduction?
I can tell the paint is fairly old and worn, original? I don't know, but the panels line up like pooo, so I was curious if there might be some identifying marks or #'s on fenders, hood, etc... that I can tell?
Thanks Guys! :-)
BurlyCrew is offline   Reply With Quote
Old 09-04-2013, 09:32 PM   #2
71swb4x4
71swb4x4's Avatar
Re: How can I identify the sheet-metal on my truck as being OEM or Reproduction?
I am sure there are ways to tell, but the gaps probably isn't one of them. These were built as trucks and the tolerances from the factory were not great. Couple that with the fact that dies were used until they were worn out, and you will have factory pieces that are going to measure slightly different.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-04-2013, 09:36 PM   #3
DGulliver
DGulliver's Avatar
Just take a hammer and give a panel a pretty good whack. If it doesn't dent, it's probably original...
Sorry, couldn't resist -but probably not so far from the truth!
'72 Chevrolet Step Side 350/TH350, '63 C10 Step V8
'74 Trans Am 400, '80 Trans Am Indy Pace Car
Mercedes AMG S55, SLK230 Kompressor, GL450
'96 Dodge Indy Ram Official Indy Truck
'99 Porsche 911 Carrera
DGulliver is offline   Reply With Quote
Old 09-04-2013, 09:36 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
If you ever look at the top of a GM fender (outside edge) near where the hood hinge bolts, you will see stamp marks in it that the aftermarket fenders don't have. Unless someone has filled them in, they are very obvious.
As far as the hood goes and the rest of the aftermarket parts, they are usually lighter in weight but that is hard to tell when it is bolted on.
TBONE1964 is offline   Reply With Quote
Old 09-04-2013, 09:51 PM   #5
BurlyCrew
lol this is probably true ha ha
Old 09-04-2013, 09:53 PM   #6
turp mcspray
turp mcspray's Avatar
Spot welds look different from original to aftermarket.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 09-04-2013, 11:03 PM   #7
BurlyCrew
How so? Bigger, smaller, deeper, shallower,etc....
Old 09-05-2013, 05:09 AM   #8
rkintn_68
rkintn_68's Avatar
the triangles are on OEM ...
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD
70 CHEVY C/10 LWB x 2 ----- SOLD
67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN "
Build thread :
http://67-72chevytrucks.com/vboard/s...15#post6826315
rkintn_68 is offline   Reply With Quote
Old 09-05-2013, 08:01 AM   #9
Many reproduction parts are the same gauge as OEM and weigh just as much. I'd say if you can't tell the difference,it doesn't really matter
