500 HP do i need disc brakes in the rear with
just got my motor and trans from proformanceunlimited 500 hp 383 stroker and th350 3000 stall...... im looking at doing the basic master power disc brakes in the front and drums on the rear will this be enough stopping power
Re: 500 HP do i need disc brakes in the rear with
Drums have more friction area, but heat up a lot faster.
Myself I would do rear disk, but it is up to your pocket book too. Or you can try to find a 77 or so Cadillac Seville as they have a 10 bolt with disks. Or I even think late model Caprices had them too. Both with the 5x5 pattern which make the swap around easier. |
i just bought the 5 lug drum conversion for the rear with out thinking about it my truck was originally a 6 cyl idk if the rear end has been replaced but it is a 12 bolt so when i bought the kit i was just blowing money with out thought trying to get all the parts in beffore i send the frame to get blasted .....the rear disc brake kit is an additional 900$ ill spend the money on i if it will make a good bit of difference but i didnt know if it would be worth it
No....You don't need disc on the rear.
![]() Join Date: Aug 2012
A lot depends on what you're asking the truck to do. Street use only? Track use (and what type of track)?
What kind of tires and what size? Don't do much good to have awesome brakes if you're running stock size street tires. I've heard it said that 70% - 80% of the braking is in the front brakes. I'd wonder if it isn't higher in a truck with the less weight in the rear ... which would make rear disc even less needed. I'll be running a built 383 with a T56 for street use only and plan on running the stock drums in the rear. Not saying I won't be looking to upgrade to rear disc in the future but initial plans for now are the drums. |
disc brakes also have have the nice feature of being able to be modulated.. which is ever so needed in a truck
also since you have a 12 bolt think of the disc brakes as a poor mans c clip elims.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
im going to run disc in rear sooner or later
![]() Join Date: May 2008
I have ran drum brakes in the rear with disc up front for nearly 10 years with a 400 hp 327 and now a 525 hp 496 for a year. Stops just fine. I am looking to replace my shocks for better ride. Goes good, stops good, need better ride.
Mine is chopped, has a clutch, and a big block. |
It will a street truck I doubt it will see the track much but I do have a lead foot and an intolerance for these pos Honda punks that are around here ... Don't get me wrong I've seen some nice Hondas but around here most are turbo piles of scrap..... And I want to run 10s or 12s on the back I have a stepside does anyone know if the will fit .... I'm running 8s up front
Posted via Mobile Device |
I run 8s on the rear with lots of room. 10s should be no problem but you need to have the correct back space.
![]() Join Date: Oct 2005
Only 500 H.P.?
1972 C10 SWB, 1970 Corvette, 2017 Grand Sport |
