Old 09-04-2013, 10:45 PM   #1
swamp rat
swamp rat's Avatar
Help!
I have tried for 3 days now and unsuccessfully to find this wheel hub seal, the part numbers are worn off. Its included in the grouping of the SBK-1 kit but this seal isn't in the kit. I stopped at the local 4X4 shop today, they have a couple seals ordered for me but they were not 100% sure ether, nobody seems to have a breakdown that lists a seal number.. Anybody?
72 K20
Dana 44-5F MFG 1971
Smaller diameter hubs
(Hub bore)= Seal OD 3.000
(Axle diameter) = Seal ID 2.005
One more question, I got these ball joints a while back almost ready to install, when i pressed the old ones out they have a smooth diameter, the new ones have serrations, is this common? the serration area measures about .007 larger than the old ones, do the serrations just get smashed down to where they look smooth?
Thanks in advance!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-04-2013, 11:55 PM   #2
vectorit
What?
vectorit's Avatar
Re: Help!
I looked on www.rockauto.com
Is this what you are looking for?
6.99 on the website.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-05-2013, 12:00 AM   #3
vectorit
What?
vectorit's Avatar
Re: Help!
I also looked up the ball joint part on rock auto.
Here is what the part looks like in the listing, and it has the ridges as well but who knows if this is the one they ship. Since the photo is just an example.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 09-05-2013, 02:01 AM   #4
swamp rat
swamp rat's Avatar
Re: Help!
Well, thats about .068 smaller than my axle on the ID, too small i think.
I appreciate your help on both posts, I'm heading to Rock auto to have a look.
Anybody else have a number??
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-05-2013, 02:04 AM   #5
swamp rat
swamp rat's Avatar
Re: Help!
http://www.rockauto.com/catalog/more...801&cc=1051445
I think my auto parts store needs to reference Rock auto.........
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-05-2013, 09:06 AM   #6
vectorit
What?
vectorit's Avatar
Re: Help!
Cool man, looks like you found your part.
I use Rockauto all the time for these kinds of parts, since it saves me fuel and frustration in going back and fourth to the local stores.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 09-05-2013, 12:54 PM   #7
Ridgeback
Re: Help!
Take a look at National Seal 472397
Ridgeback is offline   Reply With Quote
Old 09-05-2013, 01:47 PM   #8
Bigdav160
Bigdav160's Avatar
Re: Help!
The Timken seal Vectorit posted is the one I installed in my axle hubs.
My local O'reillys couldn't figure out the correct rotor hub seal and I looked it up on the Timken webpage and ordered it from Rockauto. Sure looks like it's going to be too big although the number from the old seal crosses to the same Timken seal number.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-05-2013, 08:04 PM   #9
swamp rat
swamp rat's Avatar
Re: Help!
I ordered the 472397 from Rock auto today, Thanks.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-05-2013, 08:29 PM   #10
Bigdav160
Bigdav160's Avatar
Re: Help!
Just for clarification and future reference I used Timken 472394 and it fit fine.
The Timken seal catalog is here.
The spindle listing is on page 115 and shows the same part number (472394) for 1960-1972
good luck
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 09-06-2013, 01:37 AM   #11
swamp rat
swamp rat's Avatar
Re: Help!
good luck
Which hubs do you have? That is the seal that 2 places ordered in for me and the ID was about 1.900 Plus some, My ID requires the 2.00 ID, if i recall correctly it was about .068 too small.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
