A day late and $1 short...
No signal from MAF
My 5.3 developed sort of a hiccup on the way to work tonight. I just reconfigured the air intake, but I don't think it changed the positioning of the MAF sensor much. I have a reading of 0.2 lb/min almost all of the time, idle or 3000 rpm and occasionally spikes to 60+ lb/min then back to 0.2 lb/min. If the MAF is dead why does the engine still run? Is it dangerous to drive it much with out it? I found some values to check for on the harness, but the wiring seem to be in good repair. I have never really paid much attention and this issue has made me curious. What type of readings do you all get at idle and at cruising rpm?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
Re: No signal from MAF
Well, the MAF seems to be working. I pulled the fuse and reinserted it, not sure if that sent helped it or not, but the stumble is still there intermittently. I am going to move the MAF back to the TB to see if it clears up. If not, I'm going to check fuel pressure just to make sure its good. Just got off work so I'm going to take a nap first!
meowMEOWmeowMEOW
Engine can run without half of its sensors (o2 maf, tps, etc) but it won't run correctly throughout the table, nor will it drive the same when things like DBW are involved.
Could be the MAF is really dirty, especially if you've oiled the air filter and put the MAF very close behind. A little MAF spray can clean it up, as well as looking at the position and clocking of your MAF . It should sit upright between 10 and 2 if u think about it like a watch.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I had the same problem on my truck too. It was idling around 300 RPM and would die at stoplights randomly. The MAF was a little dirty, but not bad cleaned it anyway. Also pulled off the throttle body and there was bunch of gunk on the backside that was interfering with the sensor somehow, so I cleaned that up really good. Also put a new o-ring on the canister purge valve, made sure it was sealed tight. I did that about a year ago and the truck still runs good.
Also the truck will run without it, but will run like crap. Hope this helps! |
I put the MAF directly on the throttle body and all symptoms went away. Now I need to rethink the layout of my CAI... One thing that limits my options is the length of the pig tail for the MAF, I may have to ask the guys at PSI to make me an extension.
Might be able to find the plugs at eficonnection.com and make your own for cheaper.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
I'll take a look, thanks for the link.
You could also cut the wire and solder and shrink tube longer pieces in and done. That worked for me when I rewired my engine harness.
meowMEOWmeowMEOW
don't solder anywhere close to the maf if you can avoid it. While many sensors can handle the external heat from the engine, its good to avoid heat INTO the sensor. It also helps to match the wire size and not go smaller to avoid heating or breaking the wires (not as big a threat on .5v and other ultra low voltage components)
