Old 09-05-2013, 12:12 PM   #1
88Lt1wagon
Soda blasting
Do you think they realize they're "ruining" that patina? http://www.powerblocktv.com/two-minu...th-baking-soda
-Jason
'66 C10 LWB 2 BBL 283 w/ T-5
'90 V1500 Suburban TBI 350 w/ 700R4
88Lt1wagon is offline   Reply With Quote
Old 09-05-2013, 10:54 PM   #2
donthekawguy
donthekawguy's Avatar
Re: Soda blasting
I like the patina and new paint. Anything is better than rattle can gray primer. lol Wonder how big of a compressor you need to run that blaster.
66 shorty
donthekawguy is offline   Reply With Quote
Old 09-06-2013, 12:15 AM   #3
88Lt1wagon
Re: Soda blasting
I'm not sure, I haven't used any kind of blaster yet, but it looks pretty slick, and I'd think the soda would cost less than sand/glass/walnut shells.
-Jason
Old 09-06-2013, 01:34 AM   #4
lasher78
lasher78's Avatar
Re: Soda blasting
well i just bought one just like one in video from HF and bought the valve set up that converts it to soda i have a 5gal compressor and was told it would work fine can even be operated on a little bit smaller one but i dont know about that. dont think i wouldd try it on a smaller one. i am foing to try it out one of these weekends on a set of old rallies. said can use playsand just make sure to dry it out good like put it on trap and spread out untill dry then run it thru sifter to get out big chunks of junk. that is what i am going to try first, the soda is 39.99 for a 50lb bag.
live like you are dying
lasher78 is offline   Reply With Quote
Old 09-06-2013, 07:20 AM   #5
Lugnutz65
Lugnutz65's Avatar
Re: Soda blasting
Lasher78,
DO NOT use play sand or any SAND for blasting. You will get silica in your lungs and silicosis CAN and WILL kill you. It is not safe. There are other products that can be used for blasting that are safer. Yes, people still use sand to blast but they have a full respirator with fresh air that completely isolates their lungs from the silica dust.
I doubt very much that a 5 gallon compressor will be enough to run a soda blaster unless the project is very very small. My 20 gallon will only allow me to run my pressure pot blaster about 1 minute before I need to stop and let it catch up. Most media blasters will require upwards of 10 - 15 cfm at 90 psi.
I use Black Diamond 80 grit from Tractor Supply Co. The 50# bag is only $9.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 09-06-2013, 08:35 AM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Soda blasting
I will second the dangers of "sand" also Soda leaves a residue so it must be cleaned thoroughly before any paint is sprayed. I know a guy who does glass blasting and that is good but it does leave a nasty mess whereever you do it.
I have a HF blaster and also use the TS Black Diamond but only on the small stuff. I have a 5 gal compressor and it has to catch up alot. I have used two compressors one time in tandem to blast some frame parts and it worked well but I also had to stop and rest but not as often.
Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-06-2013, 12:26 PM   #7
gofastnut
gofastnut's Avatar
Re: Soda blasting
I've got a "home made" soda blaster. It's one of those $20 stick the tube in a bucket type blasters that I use with a big box of regualr baking soda. It works great for taking paint of slowly and gently, light debris, but no rust.
Yes, it does leave a coating that a quick water wash off will take care of, then you're done!
I've done some small jobs with silica sand a few years back....saving up for a blast cabinet(and real blast media). Or, a really good respirator. The thought of cancer again doesn't thrill me....
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 09-06-2013, 01:05 PM   #8
Lugnutz65
Lugnutz65's Avatar
Re: Soda blasting
Since Baking Soda is a base, plain water will not neutralize it as well as a weak acid like vinegar. I read it somewhere, but have not tried the following tip. After soda blasting, rinse with water and then another rinse with 50/50 vinegar/water followed by a final water rinse. That should neutralize the base properties of any remaining soda residue. If you spray an etching primer on soda blasted metal without first completely neutralizing the soda, then the acid properties of the primer will be neutralized and the primer will not adhere properly.
Old 09-06-2013, 03:14 PM   #9
lasher78
lasher78's Avatar
Re: Soda blasting
so i guess the blaster was a waste of money, perfect. story of my life and this project. it will be returned tomro.
Old 09-06-2013, 07:22 PM   #10
gofastnut
gofastnut's Avatar
Re: Soda blasting
As I understand it correctly, you can wash it off with water, not rinse, but actually wash.
I've soda blasted, washed/dried and then powdercoated parts. Over a year ago with no problems. I think the biggest problem would be the little crevices clean, but no worrys so far.
DON'T SEND IT BACK!!!!
Jeff
C-10 Club
Old 09-06-2013, 07:35 PM   #11
jdl71
jdl71's Avatar
Re: Soda blasting
Did Trucks do a full build on this truck? It's apparently been a while since I've watched it, last I remember it was Stacy David not Kevin Tetz and I really wasn't sure it was still on.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 09-07-2013, 02:04 AM   #12
spacedebris
Re: Soda blasting
Stacy David left the show several years ago. He had a problem with the sponsors/manufacturers crushing the trucks after completion. He now has his own show Gearz on Velocity. Trucks and the rest of the "power block" has gone downhill the last few years. Now they are more like infomercials than the old how to shows. Now they are 5 minutes of how to and 17 minutes of sponsor ads
spacedebris is offline   Reply With Quote
Old 09-07-2013, 10:09 AM   #13
Old Bleu
Old Bleu's Avatar
Re: Soda blasting
I have a 100 lb. Eastwood media blaster. Would like to be able to try soda blasting, but the adapter kit is $140! That's more than I paid for the media plaster itself. It is on "sale" right now for $80, but that still seems like an awful lot for what looks like a couple of valves, fittings and hose. Anyone have a good alternative?
Old Bleu is offline   Reply With Quote
Old 09-07-2013, 08:31 PM   #14
lasher78
lasher78's Avatar
Re: Soda blasting
well the set up i just returned to Harbor Freight had a valve set up with hose that was only 19.99. it just screwed on to the bottom of blaster directly to tank. may look it up online and see if the fitting would work same on yours.
Old 09-07-2013, 08:41 PM   #15
Old Bleu
Old Bleu's Avatar
Re: Soda blasting
Yeah, that looks like it would work. Looks just like the Eastwood item and both say that they fit 3/8 or 1/2" outlet. Thanks!
