What is this crap around my water neck?
I assume this is calcium from someone using tap water in the coolant but I don't know. I'd think my dad would know to use distilled but what is this stuff?
I removed the hose to the water neck and it leaves a residue that falls down onto the engine...I wipe it off with water and boom it's back once it dries. ![]() |
![]() Join Date: Jun 2012
Re: What is this crap around my water neck?
I suppose your right, my house water does the same thing to the showers and sinks
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
OMGosh, I just took a look inside my hoses.........YUCK.
Royal flush needed for sure! S&S |
Old member
Looks like to me u need to mix some anti freeze into the water. Pure water is useless in a vehicle just like no thermostat is not good to run without. I use regular water in all my vehicles and none of them have this. I use a good antifreeze mix in all of them also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
It happens when water runs into disimilar metals and is quite common.
![]() Join Date: Nov 2012
If your neck is aluminum, it's probably aluminum oxide. That's aluminum's version of rust. If you wire brush it you'll probably find it has small pits. You should wire brush it and paint it before you reassemble it. It shouldn't cause any problems if you put in your proper 50/50 mix of antifreeze. I recommend Prestone only, most other kinds are junk and don't have the corrosion preventatives that prestone has. I don't represent prestone, this is just from my own personal experience.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
